Exhaust tip/tips painted black
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whisk3ythrottle, Feb 14, 2014.
  1. Feb 14, 2014 at 6:27 AM
    whisk3ythrottle
    whisk3ythrottle [OP] Well-Known Member
    Colin
    Birmingham, AL
    2010 DCSB sport 4x4
    Front windows matched tint, weathertech front husky rear mats, K & N CAI, Borla cat-back exhaust, 265/70/17 Goodyear Wrangler Authorities, fog light anytime, 5100s up front set at 1.75" on stock coils,
    I have purchased a borla cat back, single exit, exhaust system and it is being shipped currently. I was considering painting the tip flat/matte black to make it not stand out as much because I'm not a huge fan of chrome. Has anyone tried to paint a borla exhaust or similar exhaust? Pictures would be great also.
    When it comes to paint, I am considering grill paint (heat resistant) or bed liner paint (rhino liner or similar company). I'm not sure if the rhino liner would hold up to the heat so any suggestions are great. My other concern is the paint chipping away with a few months after a few rocks bounce off of it and I don't want to have to repaint it every few months so if anyone has tried this and had/not had luck with it then please let me know.
  2. Feb 14, 2014 at 6:38 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    A while back I decided to plastidip my back bumper black. While I was at it, since I had some extra left over, I also did the tailpipe. I wasn't fully expecting it to last but it has for several months. It has faded a little bit but is still on there and not peeled off. If this is holding up, I am sure rattle can bedliner will also. If not, you can always get it powder coated for pretty cheap. Even if it does come off, it only takes a few minutes to do it again, not like it is a difficult task.
  3. Feb 14, 2014 at 6:45 AM
    whisk3ythrottle
    Colin
    Birmingham, AL
    2010 DCSB sport 4x4
    Yea I hadn't even considered plasti-dip. I will probably do that so if it starts coming off, I can completely peel it off and re-do it instead of having to get some sort of paint remover to remove other paints. Thanks for the picture
  4. Feb 14, 2014 at 6:49 AM
    ChiefManyWrenches
    Florida
    No problem, I am happy with it. Like you said, if it starts coming off I will remove it and redo it. I am not sure how easy it will be to remove though after being baked on but nothing a little sand paper wont take care of or a wire wheel on a grinder maybe.
  5. Feb 14, 2014 at 7:50 AM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    Rust-Oleum makes a high-temp barbecue paint that works well and can be easily touched up with repeated applications. I've used it for years on non-stainless exhaust systems including tube headers and it has an advantage of being somewhat rust inhibiting and doesn't require elaborate preparation. I'm sure there are other similar products, but with a little care Rust-Oleum paints do very well.
  6. Feb 14, 2014 at 8:27 AM
    kiefer squared
    kiefer squared Well-Known Member
    Kiefer
    Virginia
    '13 TRD
  7. Feb 14, 2014 at 8:38 AM
    whisk3ythrottle
    Colin
    Birmingham, AL
    2010 DCSB sport 4x4
  8. Feb 14, 2014 at 8:40 AM
    kiefer squared
    Kiefer
    Virginia
    '13 TRD
    It's pretty glossy
  9. Feb 14, 2014 at 8:44 AM
    ChiefManyWrenches
    Florida
    For what it's worth, my only preparation was wiping it off with a wet rag and then a dry one. Basically got the dirt off and called it good.
  10. Feb 14, 2014 at 8:50 AM
    whisk3ythrottle
    Colin
    Birmingham, AL
    2010 DCSB sport 4x4
    Good to know. I'll probably go with some rubbing alcohol, seems to do the trick with my past experience.
  11. Feb 14, 2014 at 8:51 AM
    whisk3ythrottle
    Colin
    Birmingham, AL
    2010 DCSB sport 4x4
    Gotcha, I like the idea though and its a great price. I bet there is a similar product with a matte/flat protectant/sealer layer.
  12. Feb 14, 2014 at 8:56 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
  13. Feb 14, 2014 at 9:56 AM
    whisk3ythrottle
    Colin
    Birmingham, AL
    2010 DCSB sport 4x4
    Right now I'm kind of in between rust-oleum flexi-dip and plasti-dip.
  14. Feb 17, 2014 at 7:00 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I did mine with PlastiKote Hi-Temp paint. From the label; "Highly durable silicone resin, ideal for headers and exhaust manifolds, withstands intermittent heat up to 1300F." Followed the directions, cleaned it up with MEK and cured it in the oven. So far, so good. Good luck.
  15. Feb 17, 2014 at 7:47 AM
    whisk3ythrottle
    Colin
    Birmingham, AL
    2010 DCSB sport 4x4
    Yea I bought a similar product to this and that is what I'm going to go with. I'm pretty sure the tip is welded on so I don't know how I will cure it yet. My thought now is to use the truck to heat it up but I was planning on painting it before I install it. Any suggestions?
  16. Feb 17, 2014 at 7:58 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I just used plain ole flat black spray paint, worked fine. Pretty much anything you use is going to fade and look like poop after a while anyway.
  17. Feb 17, 2014 at 9:32 AM
    Kozy22
    Kozy22 Member
    RI
    Trd sport
    Have my tip on order. I'm going to plasti dip black with a 1/2" left chrome on the end
  18. Feb 19, 2014 at 11:21 AM
    whisk3ythrottle
    Colin
    Birmingham, AL
    2010 DCSB sport 4x4
    went with plasti-dip. Put about 4 or 5 coats on there and it turned out great. I have the mudflaps on now to kinda protect it but I'll take those off once I get some new tires and lift.
  19. Feb 19, 2014 at 11:53 AM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    Nice job. Looks awesome. Good idea putting the mud flaps on to protect against getting blasted by the rear tires
  20. May 24, 2016 at 9:18 AM
    Mogwai
    Mogwai Member
    Josh
    Ga
    2015 TRD Sport DCLB
    How long did this last on the tailpipe? I've got some plastidip left over and I'm thinking about doing the same thing...
