Exhaust vs Cold Air Intake
Discussion in 'Performance and Tuning' started by Westdog976, Dec 22, 2008.
Exhaust or Cold Air Intake
  1. Exhaust
    489 vote(s)
    62.5%
  2. Cold Air Intake
    293 vote(s)
    37.5%
  1. Feb 21, 2012 at 8:34 AM
    #101
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    There is no cam. I said cam gears. Our engines have 4 cams. The cam gears are specifically for the exhaust cams. It is the exhaust cam gears that replace the factory ones. They came with the APR X-1 kit.
    It seems you overlooked the point where I stated that it is an auto and can not be done any lower. The cam gear increase scavenging across the whole rpm range. Not just the upper. They allow a small overlap of the intake and exhaust cams to aid in intake air push combustion exhaust out. Thus improving efficiency, cooling the combustion chamber, and increasing power, by way of scavenging. If you want more info on how that works, best bet is to study up on different types of cams. If you want a simplified version, go here: www.aprpower.com
    The point of my reference was that not one part alone made his levels that high. They each contributed.
    How can you ask, "what does that have to do with a daily driver with a air cleaner and a muffler change,"? His vehicle is his daily driver. With a few extra bolt-ons.
    Did you even look where I directed you yet? I know you are curious. That is why i directed you to a source that has tons of data on you specific question.
    Increase efficiency increase power. Simple. Keep your foot out of it, and you will also increase gas mileage, if you want to.
  2. Feb 24, 2012 at 8:22 AM
    #102
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    The build so far: ProEFI Pro128 EMS [] CP Pistons [] Pauter Rods [] Brain Crower Billet Knife Edged Crank [] ARP Head Studs [] Dual Valve Springs w/Ti Retainers [] Cometic Head Gaskets [] Aeromotive Stealth 340 LPH Fuel Pump [] Tomei Fuel Pressure Regulator [] Injector Dynamics 1000 cc Injectors [] Killer Glass Radiator Tube [] Top Fuel Oil Catch Can [] Torspd Custom Turbo Header [] Polydyn Ceramic Coated Header and Merge Collector [] Precision Turbo 6265 Journal Bearing [] TiAL BOV and Wastegate [] Greddy Profec B II Boost Controller [] Intake Manifold Spacer [] NST Waterpump Pulley [] Caltrac Traction Bars [] One Piece Driveshaft [] Tundra Racing 4x4 Rear Lowering Kit [] QA1 Adjustable Front Coilovers [] Spec Stage 3+ Clutch [] T56 Transmission in waiting as well as motor being sleeved by Darton. Last edited by Torspd; 02-21-2012 at 10:39 AM.
    I would listen to this fellow! This is someone who has done his homework, you don't see PaceSetter header here.
  3. May 21, 2012 at 9:37 AM
    #103
    blkbelt42
    blkbelt42 Well-Known Member
    2016 Black DCSB 4x4 TRD Sport Loaded!
    JL Audio C2690tx Speakers Amp - Alpine MRV-F300 JL Audio 10" Sub in Full length Ported Box BFG KO2's Tint N-Fab Bars Husky WB Mats AVS Visors Console Divider Tacoma Tonneau Cover ALL PRO 1.5" wheel spacers AFe CAI w/ Dry Air filter TRD Wheels Remote Start Blacked out Stock Grille
    CAI & replace the muffler
  4. May 31, 2012 at 6:01 PM
    #104
    KaeserTRD
    KaeserTRD Member
    Kyle
    Loganville, GA
    03 2.7L PreRunner SR5 TRD
    Iconic step bars
    Put in a good muffler and a AFE filter. I really doubt you will notice much power from either, just better throttle response and a deeper tone.
    I would steer away from a cat-back on a N/A truck, the exhaust seems to be already pretty free flowing (except for the muffler). If you ever go supercharged or turbocharged then I would definitely go for a much larger exhaust.
    Here is my favorite muffler.....
    http://www.jegs.com/p/Hooker-Headers/Hooker-Headers-Aero-Chamber-Mufflers/744863/10002/-1
    I had them on two vehicles I owned in the past and my buddy put on on his V6 Ranger. Great tone, free flowing, and it will not cause drone on the highway.
  5. May 31, 2012 at 8:10 PM
    #105
    aptech
    aptech Jetfixer
    Adrian
    houston (angleton)
    10 dc offroad
    daystar level kit, tsb rear spring, ghostflames, sport hood, tsb steering, trd cai, red map lights. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall
    yap best bang for the buck
  6. May 31, 2012 at 8:13 PM
    #106
    aptech
    aptech Jetfixer
    Adrian
    houston (angleton)
    10 dc offroad
    the guy from urd had some pretty intresting dyno runs with all diiferent config. he stated that the secondary filter made absolutly no differance in or out it was the same hp either way. the only way to can hp would to change the box ie cai system.js
  7. Apr 21, 2013 at 10:50 PM
    #107
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    In the Exhaust vs Cold Air Intake option, I chose neither and went with a header instead for more low rpm performance.
  8. Apr 28, 2013 at 6:04 PM
    #108
    Khaos
    Khaos Big Member
    Bryant
    Tallahassee FL
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    I have a K&N intake filter and a Magnaflow muffler. Total cost for both parts was less than $100, I'm satisfied and my truck sounds great.
  9. Apr 28, 2013 at 10:55 PM
    #109
    tooter
    Greg
    Los Angeles
    I hear ya. :)
    After listening to the 2.7 muffler youtubes, I ordered a Magnaflow. Love that sound. ;)
  10. May 22, 2013 at 6:59 PM
    #110
    DSully72
    DSully72 Well-Known Member
    Daniel
    Newport News, VA
    04 PreRunner TRD Off Road
    if you are going for sound, cant go wrong with magnaflow. the CAI is cool, but not for off road. I know yall 2nd gens cant do the deck plate mod, but I plan on taking out my CAI and doing the deck plate mod not too far down the road from now. is the TRD intake box water tight?
  11. Jun 9, 2013 at 9:41 AM
    #111
    tooter
    Greg
    Los Angeles
    That's the drawback with auto dyno runs. They're highly informative if you're racing, but totally useless for regular everyday drivers. I could drive for 6 months without ever coming close to 3,400 rpm. I'll be doing a baseline 2.7 dyno soon to compare changes from future mods, and it'll start at 1,500.
  12. Jun 9, 2013 at 1:17 PM
    #112
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Define water tight
    1st response would be "no" due to it needing air
    Second response being, "no" due to bolts going through lid and bottom.
    "Resistant" would be closer, meaning its ok in rain.
    And what's wrong with an intake offroad?
    There's more than 1 type/brand of filter to use, plus prefilter socks
  13. Jun 12, 2013 at 12:26 AM
    #113
    NorthCountryEvo
    NorthCountryEvo Member
    Arizona
    '13 TRD Sport 4.0 V6
    So, what is the best options here not only for sound, but for fuel economy? Performance gains are great, but I'm curious as to what is going to boost the fuel econ the most as well
  14. Jun 12, 2013 at 12:34 AM
    #114
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Fuel economy..... keep ur foot light.
    I get the same mpg now with blower, intake, headers, y pipe, 3" exhaust as I did without.
  15. Aug 1, 2013 at 10:36 AM
    #115
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Can people stop reviving old threads already the guy chose already if you read it all and the op has not been on since November so let the thread fade away
  16. Aug 1, 2013 at 10:48 AM
    #116
    Wolfman87
    Wolfman87 Member
    Forrest City AR
    2015 red DCSB TRD
    Backup camera anytime mod.
    I know you have already installed the exhaust but for anyone else wanting to know.... The exhaust is a better first mod because a CAI is simply pushing denser air into the engine. The way that most modern day car companys build their vehicles today is with the breather pulling air from the fender well. This is a simple type of CAI as the feneder well is a high pressure zone and selected based on performance aspects. Im sure any after market kit would boost the performance but to get the biggest change an exhaust is the way to go..... IMHO
  17. Oct 13, 2013 at 8:08 PM
    #117
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    . Do u think one should replace the entire exhaust or just the muffler, and why out of curiosity?
  18. Oct 13, 2013 at 10:42 PM
    #118
    Tacodriver
    Tacodriver Active Member
    AZ
    2011 prerunner
    deflapped debadged snow filter delete bed rail delete K&N drop in
    Tough call. Im in the same boat. I think Im just getting a cat back with a drop in filter.
  19. Oct 13, 2013 at 10:47 PM
    #119
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Compare the stock pipe diameter to a catback.. I'm curious and don't have my stock setup anymore.
    Also these trucks have been dynoed with stock filters, a k&n, no air filter, then no air filter, and the carbon filter removed..... No HP increase in any of those configurations over stock. The k&n actually lost HP.
    The restriction is the housing/ducting/silencers/baffles.
  20. Oct 13, 2013 at 10:50 PM
    #120
    Tacodriver
    AZ
    2011 prerunner
    I like the magnaflow off road exhaust. Im sure it makes some power and weighs a lot less, since it only has a resonator or muffler vs stock resonator and muffler.
