Exhaust will screw up car?
Discussion in 'Performance and Tuning' started by Burner1061, May 12, 2021.
  1. May 12, 2021 at 10:24 PM
    Burner1061
    Burner1061 [OP] Active Member
    I was looking at buying the Flowmaster Part# 17432, but this Scotty Kilmer video popped up on my Youtube feed and it basically says aftermarket exhaust systems WILL screw your car up. Is this true for Tacomas? That video scared me lol because I don't want to drop $600 on something that could potentially ruin my Taco. Thank you in advance.
  2. May 12, 2021 at 10:37 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Scotty is a sensationalist, click baiting jackass who panders to non enthusiasts who don't know any better. Plenty of people on here run aftermarket exhaust or mufflers without any issues. Do your research on here not watching that ballsack.
  3. May 12, 2021 at 10:40 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    ^^^true that. Scottie is a loose cannon.
    however, some exhaust systems without proper tuning may take away low end power. Specially if used in natural aspirated applications.
    BassAckwards and Burner1061[OP] like this.
  4. May 12, 2021 at 10:52 PM
    Burner1061
    Do you think I will have to worry about that with the Flowmaster I linked?
  5. May 13, 2021 at 5:21 AM
    henryp
    Henry
    Montana
    I don’t know specifically about this one. Check out the hp tuners and JFR equal length y-pipe threads for some good info on custom tunes and exhausts. You might also try to find out if anyone has run a dyno after getting this system.
    Torspd likes this.
  6. May 13, 2021 at 5:32 AM
    Honda2Toyota
    Honda2Toyota Your Local Long Bed Enthusiast
    Spotsylvania, Virginia
    2016 Tacoma DCLB TRDSport
    -Leer Camper Shell -Bilstein 5100 in the front and Bilstein 5100 in the rear with Icon AAL -TRDPro Front Grille -FJ Cruiser Steel Wheels with BFG AT KO2 Tires -MESOCustoms PTS Button -Prinsu Roof Rack with 40" LED Bar -ARB Awning -ARB Summit Front Bumper -ProComp front Spotlights and Cree Dual Beam combo bar -ARB skid plates -OVTune Trans Reflash
    Nothing about any aftermarket or performance exhaust system will ever 'ruin' your vehicle directly. I've had countless aftermarket exhaust systems over the years, from dirt bikes to four wheelers to motorcycles, cars and trucks, etc. Now, if you enjoy the sound/performance so much that you find yourself constantly in the throttle, that isn't always the best for fuel economy OR longevity. lol
    Regardless, modifying the breathing capabilities of any internal combustion engine without properly accounting for the amount of fuel/air it needs to perform at its best, can provide a variety of results. Considering that our trucks use an 02 system and monitors fuel trims, I wouldn't hesitate to install a basic exhaust system(or the one you linked)if sound was truly all I was after. Worst-case scenario, get the truck dyno-tuned/re-flashed if you truly want to be on the safe side and make sure the truck is running ideal fuel trims after installation.
  7. Jun 11, 2021 at 12:04 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    modern vehicles have closed loop tuning and ability to change fuel trims and timing. freeing up the exhaust wont do anything to "ruin" your truck. toyota themselves offer the trd exhaust.
  8. Jun 28, 2021 at 7:16 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    the OEM EPA setups are drsigned to work together within Engineered parametres
    when various sensors are out the ECU can operate within those parametres
    CEL codes follow
    parts are replaced
    look at some of the tuner / fart cars running around.............
    lots of noise
    maybe......... Maybe increased performance ?!?!?!?!?!?!
    the tell tale ‘ black bumper ‘ !!!!!!
    the EPA mandate excercise demands the engines have been ‘ Leaned ‘ out !!!!!!! ( cant be argued )
    so Adding ‘ fuei ‘ helps to an extent
    YET
    the ECU gives up on metereing/ compensating ( idle - redline ) simply because almost eveything is out o whack !!!
    true there is MORE noise
    MORE Giddy Yap!!!! .............most at WOT
    a visceral DYNO seat o the pants 1st person success
