exhaust.....
Discussion in '5 Lug' started by DrunkenDangler, Jun 21, 2011.
  1. Jun 21, 2011 at 12:12 PM
    DrunkenDangler
    DrunkenDangler [OP] Well-Known Member
    AL
    2005 5 lug access cab
    fat bob lift
    what kind of after market exhaust do you recommend for hp and gas mileage on a 5 lug?
  2. Jun 21, 2011 at 12:13 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    Magnaflow
  3. Jun 21, 2011 at 2:10 PM
    DrunkenDangler
    AL
    fat bob lift
    Damn i figured it would since people always talk so good about the taking the charcoal filter out. I thought putting a new exhausts would be 100 times better
  4. Jun 21, 2011 at 2:11 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Check out my build thread. I got some videos with my Doug Thorley exhaust and headers. I think it sounds great for a 4 cyl.
  5. Jun 21, 2011 at 2:16 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Exhaust wont do much, if anything at all.
    You will probabbly LOSE mpg cause you'll wanna step on the gas more so you can hear it... That's what happened to me anyway :D
  6. Jun 21, 2011 at 3:29 PM
    DrunkenDangler
    AL
    fat bob lift
    I put a fat bob lift and 30s on yesterday
  7. Jun 21, 2011 at 3:51 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    Looks good. You should start a build thread
  8. Jun 21, 2011 at 3:53 PM
    DrunkenDangler
    AL
    fat bob lift
    tires have really seemed to bog it down whats the best ways to increase hp on the 5 lugs
  9. Jun 22, 2011 at 12:19 AM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    supercharge it :rolleyes:
  10. Jul 24, 2011 at 6:18 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    40 series flowmaster with lce header. truck runs smooth and sounds good. im very happy with it.
  11. Jul 24, 2011 at 7:34 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    RE-GEAR the truck.
    I have a Magnaflow and it sounds like shit. :rolleyes:
  12. Jul 31, 2011 at 1:06 AM
    2TRunner
    2TRunner Well-Known Member
    Ohio
    13" Wicked Flow on mine. Link below.
  13. Jul 31, 2011 at 11:24 AM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    i cut off the stock exhaust and welded a cherry bomb pro muffler. If you replaced the intake header and exhaust with a calibrator from URD your only going to have maybe 15 to 20 added hp total. it doesn't do much other than burn a hole in your wallet.
  14. Aug 2, 2011 at 12:51 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    no hp or mpg gain from exhaust...just louder than stock :)
    i have lce header with magnaflow exhaust, lost torque gained more hp.
