exhuast manifold crack
Discussion in '1st Gen. Tacomas (1995-2004)' started by GreenYota, Jul 10, 2011.
  1. Jul 10, 2011 at 6:13 PM
    GreenYota
    GreenYota [OP] Member
    David
    lake placid FL
    00 taco 2.7 l 3" lift 33 baja claws
    Toyotec 3" lift, k&n fipk, kicker 10" l7
    My 2000 tacoma 2.7 l exhaust manifold keeps cracking y and how to pervent it
  2. Jul 10, 2011 at 6:26 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    Cracking on the 2.7 manifold is a known problem. I would buy a dt header!
  3. Jul 12, 2011 at 6:35 PM
    totalloser
    totalloser New Member
    99 3.4 4x
    Mostly stock (new 2 me)
    I run a Thorley on my Samurai, primarily due to having an EO# for smog. On my old 2.7 truck I ran a LCE because it's a better header. It's stainless, and ceramic coated instead of chrome plated. Ceramic blocks a lot of heat from the engine compartment.
    It was the first 4 to one header I've run and I was expecting minimal bump in low end, and was pleasantly surprised at the low end performance. Reuse your STOCK egr gaskets. I did have the collector gasket blow out a few times and replaced it with an aluminum ring which lasts to this day.
