Exhuast Manifold
Discussion in '1st Gen. Tacomas (1995-2004)' started by sisalee, Aug 12, 2010.
  1. Aug 12, 2010 at 9:52 PM
    sisalee
    sisalee [OP] New Member
    I have a 99 Toyota Tacoma. I bought it about 2 years ago. When I purchased it I had a cracked exhaust manifold that I had replaced with a new one in October of '08 since then the new one has cracked (I am estimating this happend about 4 or 5 months ago) Does anyone know what might be causing this to repetitively happen?
  2. Aug 12, 2010 at 10:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Which motor? 3.4L, 2.7L or 2.4L?
  3. Aug 13, 2010 at 9:45 AM
    sisalee
  4. Aug 13, 2010 at 3:29 PM
    Digiratus
    Roaming the PNW
    The RedHead
  5. Aug 19, 2010 at 1:22 PM
    vapovick
    vapovick Active Member
    1999 Toyota Tacoma 4x4
    Im interested in this as well. I just replaced mine, 117.00 from O'reillys. When I pull the old one it had a crack all the way around, I intentionally dropped it from about 3 feet, and it split in two, there was only about 30mm where it was attached prior to the drop. Only about 30mm didnt have rust on it, in the process (before installing the new EM I blew both O2 sensors, bank 1 sensor 1 and bank 1 sensor 2, quite an expensive fix. Its working like a champ now (crossing fingers) and all engine lights are off. :) good luck!
  6. Aug 19, 2010 at 3:48 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Where is it cracking? Your exhaust flange may not be truly flat, which may put strain on the manifold. Then when it heats and cools it expands and contracts. Then it gets weak and cracks.
  7. Aug 19, 2010 at 9:47 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Very common for the 2.7 engine. Mine was cracked really bad when I bought my truck. So bad that you could smell exhaust when the heater was on.
    I would recommend buying a set of headers (solid steel tubing=stronger and less prone to cracking). Stay away from Pacesetter, though. I've heard bad things about them and you get what you pay for. I got a set of ceramic Doug Thorley Tri-Y headers from TRDparts4u.com for under $400.
  8. Aug 20, 2010 at 11:59 AM
    sisalee
    I have been talking with a few local mechanics regarding my situation. I was able to get my Dorman Manifold replaced through lifetime warranty but will have to pay someone to do the labor again. The mechanic I am working with told me that Tacoma's are known for this happening as well as Jeep Wranglers. "It's like a design flaw" He also told me it could be the manifold itself, and I could have gotten a bad one. Any thoughts on this?.........
