Expanding our deck from 120 SQ/FT to about 550 SQ/FT
Discussion in 'Garage / Workshop' started by BTR, Jul 29, 2013.
  1. Jul 29, 2013 at 8:52 AM
    BTR
    BTR [OP] Well-Known Member
    Mass
    06 Tacoma 4x4 v6
    Our current deck is about 10x12 and so we cant fit patio furniture and a grille out there at the same time. Since its not a raised deck (where we could possibly fall to our deaths) I decided to tackle it myself.
    Photo of existing deck after I dug up the area for the new one.
    5-26-13
    Uploaded with ImageShack.us
  2. Jul 29, 2013 at 8:53 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    5-29-2013
    So I realized that my house was built on ledge today, there is nothing but rocks in every direction of this build. it was a disaster getting all of them out to dig the holes for the posts.
  3. Jul 29, 2013 at 8:56 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
  4. Jul 29, 2013 at 8:56 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    6-10-13
    Extra tubing cut along with wood from our local home improvement chain
  5. Jul 29, 2013 at 8:57 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
  6. Jul 29, 2013 at 8:59 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    6-19-13
    Ran into a huge snag, with all the rain the holes keep filling up with water. Everytime I drain the hole it fills up again. turns out that there was a large pool of water behind my house gathering on top of a rock. It took about 2 days with a sump pump to pump it out so I can start working again.
  7. Jul 29, 2013 at 9:00 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    6-22-13
    After days of pumping and struggling with it I finally got 2 more posts done. Section 2 if halfway completed. For the next two posts I may have to either pin the wood directly to the rock or attempt to make a small concrete platform on top of the rock (its about 3 inches before I hit rock on one side and 8 inches on the other)
  8. Jul 29, 2013 at 9:05 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Tremmi pipe! Water doesn't need to be out of the hole before you can place concrete as long as the base is solid (which it would be since you're on ledge). Basically, you just stick a 4-6" diameter pipe to the bottom of the whole and pour the concrete through that. Keep the bottom of the pipe in the fresh concrete and, as your keep pouring, the concrete displaces the water. Just in case you run into this situation again!
  9. Jul 29, 2013 at 9:08 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    ^^ oh boy oh boy, this would have been great info to know then lol. thanks bud!
  10. Jul 29, 2013 at 9:09 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
  11. Jul 29, 2013 at 9:09 AM
    BamaToy1997
    Bill
    Navarre, FL
    Looking good! Nice work there. I love building decks almost as much as I love relaxing on them. It is hard to tell since the color seems off by the photos, but I assume you used treated wood on all of the joists? It is probably the color of the photo, but it looks to be regular un-treated pine.
  12. Jul 29, 2013 at 9:10 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
  13. Jul 29, 2013 at 9:11 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    probably the color. its all treated wood! :)
  14. Jul 29, 2013 at 9:11 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    7-9-13
    removed remaining posts and ripped old deck down to the joists
  15. Jul 29, 2013 at 9:12 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    7-10-13
    20 foot strips of composite decking have arrived
  16. Jul 29, 2013 at 9:13 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
  17. Jul 29, 2013 at 9:13 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Thats going to be a nice big deck. What are your plans for that basement window? You won't have much of a view anymore.
  18. Jul 29, 2013 at 9:13 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    what really grinds my gears is some of the quality of the wood from the big box improvement stores. some of the wood ended up to be super wavy and uneven
  19. Jul 29, 2013 at 9:15 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    we have a second basement window but I'm not thrilled about losing all of that light either. I may install a solar motion led light under the deck that points at the basement window so that it brings some light into the basement when its dark?
  20. Jul 29, 2013 at 9:16 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    7-16-13
    laid some of the composite decking out, got it at a major discount at some clearance warehouse, its not perfect and some of the pieces are faded, but with the money I saved I'm sure I'll get over it
