Expanding our deck from 120 SQ/FT to about 550 SQ/FT
Discussion in 'Garage / Workshop' started by BTR, Jul 29, 2013.
  1. Jul 29, 2013 at 9:19 AM
    BamaToy1997
    Bill
    Navarre, FL
    That stuff does look nice. Never used it before though. I always used regular wood decking. I can't wait to see how it looks when finished.
    Maybe he can convert it into an escape hatch, and a small crawl space under the deck. lol
  2. Jul 29, 2013 at 9:19 AM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Unless you're getting a ridiculous amount of lumber, I always check in the store to make sure I don't buy (what I call) "fucky" lumber. I just do a quick check on the crown and for significant warping.
  3. Jul 29, 2013 at 9:20 AM
    BTR
    BTR [OP] Well-Known Member
    Mass
    06 Tacoma 4x4 v6
    btw this is my first time building a deck, I learned everything so far from google, youtube, talking to people, and books. so if any pros out there see something then its ok to say something...
    that being said I have no idea how to install vinyl railings... I'm especially concerned about the angles
  4. Jul 29, 2013 at 9:22 AM
    BamaToy1997
    Bill
    Navarre, FL
    You look like you are doing a good job so far. Support spacing is good, and joist thickness looks good as well. How did you attach to the house itself? Did you use a sealer and wood protector there as well?
  5. Jul 29, 2013 at 9:22 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    the big debate was whether to go wood or composite, it would have been A LOT cheaper to go with regular wood. I guess I just didnt want to deal with the maint. (staining or painting etc.) and it would take years for me to stain a deck like this
  6. Jul 29, 2013 at 9:24 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    long long bolts that go directly into the joists of the house.
    thats the thing, i did not use a sealer or wood protector as yet, I took the vinyl siding off and I'm not sure how to tackle that, someone said I need to put a moisture barrier strip or something there as well?
  7. Jul 29, 2013 at 9:27 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    bought a husky LED worklight from home depot, I needed lots of light and something that wasnt going to keep tripping my breaker with all the tools going at the same time. works great and provides a very nice sharp light for working at night
  8. Jul 29, 2013 at 9:33 AM
    BamaToy1997
    Bill
    Navarre, FL
    Yes, you really do need a moisture barrier there. At this point it would be too expensive to pull the joist and seal it, so I would suggest getting several tubes of sealer and go to town where the joist connects to the house. Get a good bead along the top, making sure it bonds well to the house as well as the board where they meet. You do not want ANY water getting past there.
  9. Jul 29, 2013 at 9:49 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Or flash it. I'd trust flashing over a bead of sealant any day. Stuff the flashing up under the bottom layer of siding, and wrap it over the joist and make a drip edge on the bottom. It would mean the last board would sit on the flashing but it'll keep water away from that joint.
  10. Jul 29, 2013 at 9:56 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    ^^yes, I believe flashing was the reccomended solution
  11. Jul 29, 2013 at 9:57 AM
    BamaToy1997
    Bill
    Navarre, FL
    I should have thought about that Mike! It wouldn't be THAT difficult to pull the first two deck boards to install flashing along the house. Good idea!
  12. Jul 29, 2013 at 10:02 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    good job, im jealous!
  13. Jul 29, 2013 at 10:13 AM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    If as you say you learned for the internet on building your deck, good job. When looking through this from the beginning I was hoping that the old small section was going to get redone too. I also recommend going with the metal flashing. I'd look into a local siding dealer, not Lowe's or Home Depot type place. They should have rolls of aluminum or tin in different colors. Then with a "break" can then be bent into the type of desired flashing or trim. I'd recommend 4 or 6 in wide stuff and have it bent in either of 2 ways.
    1) A single bend into a "L" with the short length wide enough to cover the top of the wood anchored to the house.
    2) A double bend similar to the "L" but with another bend on the short side of the "L" that angles down toward the ground.
    The second option is not as easy, the first option will work too. As long as you get some flashing that either matches your siding or the deck, then it shouldn't stick out like a sore thumb. Example the bare galvanized flashing for roofing would not look to good.
  14. Jul 29, 2013 at 10:41 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    replacing the old section meaning tearing up the old framing as well? essentially starting from scratch?
  15. Jul 29, 2013 at 10:43 AM
    #35
    BTR
    Mass
    06 Tacoma 4x4 v6
    7-14-13
    Bought this and cut down on building time significantly
    Uploaded with ImageShack.us
  16. Jul 29, 2013 at 10:44 AM
    #36
    BTR
    Mass
    06 Tacoma 4x4 v6
  17. Jul 29, 2013 at 10:48 AM
    #37
    BTR
    Mass
    06 Tacoma 4x4 v6
    my question is now that I tore the siding off, how do I go about putting it back and still making it look good? put flashing above the wood then cut new siding? do I need to buy another plastic vinyl siding bracket? or can I just stuff the siding behind the composite piece?
  18. Jul 29, 2013 at 10:49 AM
    #38
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Not sure if you had instructions with your composite... but when you get to the center part where you are putting 2 boards together, you should have put one going the opposite way in the middle. Like what you see on the right hand side.
  19. Jul 29, 2013 at 10:58 AM
    #39
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I'm not a fan of composite but lots of people swear by it
    How are you attaching it ? What brand is it ?
  20. Jul 29, 2013 at 11:00 AM
    #40
    OZ-T
    Peter North
    British Columbia
    I would cut the housewrap about 1 " above the ledger , tape that to the sheathing , install a drip edge flashing over that and under the housewrap above
