Expanding our deck from 120 SQ/FT to about 550 SQ/FT
Discussion in 'Garage / Workshop' started by BTR, Jul 29, 2013.
  1. Jul 29, 2013 at 12:18 PM
    #61
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    There isn't any siding below your ledger is there ?
  2. Jul 29, 2013 at 1:36 PM
    #62
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Nice job. Only thing i would have done differently is double some of your joists that other joist are hanging off of. That angled area i would have only ran the rim at an angle, probably doubled it, and ran the joists in the same orientation as the common joists, mainly for fastening purposes and the spans assuming all your decking will be oriented in the same direction. Again, nice job! Vinyl railings are easy, you wont have any problem with them.
  3. Jul 29, 2013 at 1:38 PM
    #63
    evanmb31
    evan
    connecticut
    09 trd off road
    I dont do much vinyl so i am no expert, but that type of undersill should be nailed on before you install the last course of siding.
  4. Jul 29, 2013 at 2:17 PM
    #64
    BTR
    BTR [OP] Well-Known Member
    Mass
    06 Tacoma 4x4 v6
    yeah I hear what you are saying, the only thing is that the angled area was more of an after thought and once I started tinkering I quickly reached the point of no return. :(
  5. Jul 29, 2013 at 2:19 PM
    #65
    BTR
    Mass
    06 Tacoma 4x4 v6
    Thanks, its called rhino decking and its super heavy..... and solid each strip weighs 60+ lbs
  6. Jul 29, 2013 at 2:21 PM
    #66
    BTR
    Mass
    06 Tacoma 4x4 v6
    Rhino deck, each strip weighs 60+ lbs, I'm attaching it using the camo hidden fasteners method
  7. Jul 29, 2013 at 2:27 PM
    #67
    BTR
    Mass
    06 Tacoma 4x4 v6
  8. Jul 29, 2013 at 2:34 PM
    #68
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    nice work so far man. I just bought some of that composite decking for the underside of my built in bbq project and you're right it is very heavy
  9. Jul 29, 2013 at 2:37 PM
    #69
    OZ-T
    Peter North
    British Columbia
  10. Jul 29, 2013 at 2:42 PM
    #70
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    You can use multiple types. These screw up from the bottom
  11. Jul 29, 2013 at 2:44 PM
    #71
    OZ-T
    Peter North
    British Columbia
    I've used that system on cedar
    but grooved boards are meant to be held down with the clips which allows for linear expansion and contraction because unlike wood , composite expands and contracts in length too
  12. Jul 29, 2013 at 2:55 PM
    #72
    BamaToy1997
    Bill
    Navarre, FL
    No, it's not really how code is. Here in Alabama, there isn't much code when doing your own contracting work. BUT that being said, I personally do not like the idea of cutting into existing house wrap if I can help it. So if I am modifying a home that has already been wrapped, I prefer adding the flashing as long as at least 4 inches of it is protruding up the wall to prevent "wicking" of moisture as much as possible. Even if moisture were to wick up, when it passed over the flashing it would still be caught by the existing moisture barrier. Of course in the OPs case, I see no signs of a house wrap at all.
    The undersill trim can be difficult in your case, since the bottom board is already installed. One option would require knowing how far up the board the lowest bolts are. If you remove the first 2 deck boards to get to the TOP of the board, and the board itself is bolted directly to the house, you can try this method (It takes a bit of work, but will help with making sure moisture stays out):
    1. Remove all of the bottom bolts that are bolting the joist to the house, leaving the top bolts in place.
    2. Slightly loosen the top bolts to allow a small amount of movement of the board.
    3. Slide the flashing behind the board from underneath.
    4. Reinstall the lower bolts, through the flashing and into the house.
    5. Tighten up the top bolts.
    6. seal all of the bolt heads that screw into the house.
    Yes, this is a lot of work, but we are talking prevention to make the wood less prone to damage over the years.
    Also remember that when slipping the flashing underneath the joist, overlap the pieces of flashing by 6 -8 inches, and apply a liberal bead of sealer onto the back of the next piece of flashing to help seal the overlap.
  13. Jul 29, 2013 at 2:57 PM
    #73
    OZ-T
    Peter North
    British Columbia
    Flashing is meant to keep the water that gets behind the siding from getting behind the housewrap or paper , putting it on top of either is pretty pointless except to direct the water that's already on the outside of the siding over the ledger
    The white behind the siding isn't TYPAR ?
  14. Jul 29, 2013 at 3:02 PM
    #74
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    I agree with OZ, the composite needs the fastener clips due to expansion. I have some experience with composite, the deck looks good so far and the PVC handrail is not difficult. I do think the OP might have some deflection when stepping on the boards due to the spacing of the joists especially on the diagonal run. Composite does not have the strength of 5/4 wood decking. Nothing to be concerned about though.
  15. Jul 29, 2013 at 5:06 PM
    #75
    BamaToy1997
    Bill
    Navarre, FL
    I agree with this. But my method does this. From inside to outside is:
    Sheething/houswrap/flashing/siding/floorjoist.
    If the water DOES get behind the flashing, it WON'T get past the housewrap. Perhaps I am not explaining my thoughts well enough? Hard to explain in text, but if you look at the photo that I first posted it shows how it all comes together, and prevents any moisture that DOES get past the flashing from getting to the house.
  16. Jul 29, 2013 at 5:18 PM
    #76
    OZ-T
    Peter North
    British Columbia
    I hear what you are saying Bill and I'm not trying to sound like a total A hole , that just wouldn't pass any code we have here .
    Water can't get behind the flashing the way I explained it unless it is already behind the housewrap
    Up here we also have to have a 10mm rainscreen drainage cavity between the siding and the " primary drainage plane " which is your housewrap or paper , and all flashings must have a 4" wall leg behind the paper above , lapped shingle style ( ie top course over bottom course ) and all flashings must have 1" end dams on them
    Carry on
  17. Jul 29, 2013 at 5:55 PM
    #77
    BTR
    Mass
    06 Tacoma 4x4 v6
    yes i noticed this as well so i added a few scrap blocks in between the diagonal runs to help with that
  18. Jul 29, 2013 at 5:59 PM
    #78
    BTR
    Mass
    06 Tacoma 4x4 v6
    hmmm. might not be horrible. the first floorboard isnt permanently secured so i might be able to take a closer look
  19. Jul 30, 2013 at 6:48 AM
    #79
    BTR
    Mass
    06 Tacoma 4x4 v6
  20. Jul 30, 2013 at 10:02 AM
    #80
    BamaToy1997
    Bill
    Navarre, FL
    No worries. I know you weren't trying to be rude or anything. I can see in my mind what you are talking about. I am honestly curious why it wouldn't pass code my way, but then again I have seen some REALLY strange code, like when I lived in hurricane prone Florida! lol.
    You CAN use it instead of flashing, but to be honest, I would use both since you are working on existing construction. But that is just me, I tend to overdo things when working on my house. For example when the inspector came to my house in Florida after I installed an add-on roof to the back deck he was laughing so hard it was crazy. I asked him why he was laughing. He responded by saying something to the tune of "I think the house would lift off the foundation before this additional roof separated from the existing one!"
