Expected brake life
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Harvo, May 16, 2018.
  1. May 16, 2018 at 4:41 PM
    Harvo
    Harvo [OP] Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    In average driving conditions, in hilly but not mountainous landscape (TN), what kind of mileage would you expect the stock brakes on a stock truck to get?
    I know tire size, load, towing, etc will all impact that a good bit, but what's the baseline like?
    Thanks.
  2. May 16, 2018 at 4:46 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Went over 100k in 1st and 2nd Gen M/T Tacoma's with no Brake Changes.
    wilcam47 and Taco16LB like this.
  3. May 16, 2018 at 4:48 PM
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    I expecting to get close to 45,000 on my fronts maybe little more. Not a heavy on the brakes
  4. May 16, 2018 at 5:01 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Too dependent on driving style to say. Hard brakers will cut through them much faster than someone who conserves momentum and uses engine braking a lot.
    Although I'd say even the most aggressive of brakers should get at least 20k. This assumes no autocross or track days.
    wilcam47 likes this.
  5. May 16, 2018 at 5:05 PM
    Harvo
    I'm asking because I have close to 30000 on mine. I just put 33s on, and I'm about to do a rally in the VA mountains that will be like 1200 miles in 3days... then driving to Colorado for a week in the mountains there.
    They look ok, but not sure if they are ok for that much more hard use. Hard to tell.
  6. May 16, 2018 at 5:06 PM
    SR5 BRI
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Yes they should be fine
  7. May 16, 2018 at 5:28 PM
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    My father got over 100k on brakes in his ranger, although the rear shoes were so thin you could have shaved with them.
  8. May 16, 2018 at 6:17 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    110k km on my second gen and running 33s the whole time. pads were down to 20%. Drums were fine still.
  9. May 16, 2018 at 6:34 PM
    woohoo_tacos
    woohoo_tacos Well-Known Member
    Atlanta
    2017 TRD off-road 4x4
    3” lift 285/70-17 TRD PRO wheels 17x7
    I got like 15000 miles out of mine. Put Brembos on and 17000 miles (current odo 32,000) later breaks pads still look like they are at 80-90%
  10. May 16, 2018 at 6:39 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    should be fine - I live in Nashville and spend a lot of weekends over in the mountains. yes I use engine braking when it makes sense but also can get the brakes a little hot. mine are barely worn after 27k miles so I'd expect to easily get 60k out of these minimum.
    shakerhood likes this.
  11. May 16, 2018 at 6:47 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    what do you mean they look ok? ;) brake pads are like tires its how much pad they have and if theres any grooves on the rotor. go to a parts store and take a look at a new set of pads, then compare them to yours. Front wear faster than rear.
  12. May 16, 2018 at 7:06 PM
    SoulArmored
    SoulArmored Well-Known Member
    Evan
    2018 TRD Off-Road
    Be sure to clean and lube slides for better wear and performance. Also clean and adjust your rear drums.
    Your rear drums should last a good bit longer than the pads. Front differs so much. I've seen as little as 20k to over 100k on factory pads from various manufacturers. (Honda pads are known for wearing very fast...even have service bulletins regarding)
  13. May 16, 2018 at 8:06 PM
    Harvo
    Just that. I looked without me ones too boltsare then to. The pads still have some cleaning groove depth in the middle.
