Expected MPG loss for a 3 inch lift and 285's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ducksman, May 31, 2016.
  1. May 31, 2016 at 5:37 AM
    Ducksman
    Ducksman [OP] Well-Known Member
    Brandon
    2016 Tacoma TRD Off-road
    Expected MPG loss for a 3 inch lift and 285's? Considering a lift and wondering if it's worth it...
  2. May 31, 2016 at 5:55 AM
    dantrd05
    dantrd05 Well-Known Member
    Daniel
    Ottawa, ON, Canada
    2016 DCLB TRD Sport
    BF KO2 with FN Fx Pro's (Matte bronze) Levelling kit 2,75" Front and 2" Rear.
    I have the 3" lift BUT 265-70-17.
    MPG was not really affected. It's negligible.
    But I am not aggressive on throttle though.
    My MPG is around: 19
  3. May 31, 2016 at 6:44 AM
    12TAG
    12TAG Member
    2016 TRDOR 4x4 White
    Bilstein/OME 3" Lift 285/70R17 Wild Country MXT
    I'm running 3" with 285/70R17 MT tires. I'm getting around 17.3 according to the computer. That should be over 18mpg when corrected for tire height.
  4. May 31, 2016 at 9:17 AM
    BeaverNation
    BeaverNation Well-Known Member
    You know there's a change tires option and the nav settings right? Will adjust for 285's by comparing the gps and odo
  5. May 31, 2016 at 9:27 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    I'm a 2nd gen and I went 3" 2" lift & level from stock TRD Sport 17" wheels & 265/65/17 to 16" wheels with 265/75/16 and lost 20-25% mph city & highway combined. Highway only is more like 15-20% as long as I keep my psi at 42. My combined ranged dropped from 420 miles max to 315. All highway miles, I can muster 370-380 miles to a tank, that's obeying the speed limit.
  6. May 31, 2016 at 10:20 AM
    dantrd05
    Daniel
    Ottawa, ON, Canada
    2016 DCLB TRD Sport
    :eek:
    You serious?
    I'll have to check this out!
  7. May 31, 2016 at 10:30 AM
    marlon671
    marlon671 Well-Known Member
    Marlon
    Bay Area, CA
    2016 Tacoma Sr5 Super White
    See build page.
    I just drove from Reno back to the bay area lastnight. 177 miles. I have a 3" lift and 285's. I got 19mpg average. Not bad considering about 60% of the drive consisted of uphill terrain.
    TWTaco and dantrd05 like this.
  8. May 31, 2016 at 10:31 AM
    Sbpark
    Sbpark Well-Known Member
    2017 Subaru Outback 2.5i Limited
    If you're considering if it's worth it and are concerned about mpg then it's not worth it.
  9. May 31, 2016 at 10:32 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    20-25% depending on load range of tires and driving style/driving area, generally speaking.
    Some less. Some more.
  10. May 31, 2016 at 10:33 AM
    marlon671
    Marlon
    Bay Area, CA
    See build page.
    True. Doing the lift and the wheels and tires, you almost have to prepare for the mpg loss... to me, its not as bad as my 14mpg i was getting on my jeep with 37's. Like the old saying goes, "you gotta pay to play"... with me, it was a good compromise.
  11. May 31, 2016 at 10:39 AM
    bdunna
    bdunna Well-Known Member
    2005 tundra access cab
    SAAAAAAAAAAAAAAAAAY WHAT! I did not know that. Thanks toyota......you where listening.
    Sbpark likes this.
  12. May 31, 2016 at 10:41 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Yeah but for every uphill there is also a downhill as you drove to Sea Level in the Bay Area
    Sbpark likes this.
  13. May 31, 2016 at 10:43 AM
    Sbpark
    Exactly. Going up to the mountains I'd get horrible mileage in my Subaru, and on the wy back I'd get amazing mpg doing down the passes. All averages out.
  14. May 31, 2016 at 10:43 AM
    12TAG
    12TAG Member
    Yes I've done this but I dont believe it affects your Speedometer or Odometer. Only your Nav unit. The reason I say this is because my daily commute to work was 18.3 miles before the tire change. Now it says 17.8 everyday. And the local PD's "Your Speed" indicators aalso show that my Speedo is still off.
  15. May 31, 2016 at 10:43 AM
    bdunna
    Mileage should drop off a bit, what you drop too depends on: what you get now, your driving habits, and any other mods. Bigger tire=more rotating mass/ground clearance (less aerodynamics), and less efficiency. I have 265/70/17's, but have not noticed a drop. Haven't noticed because I switched tires at the 13 mile mark.
  16. May 31, 2016 at 10:45 AM
    marlon671
    Marlon
    Bay Area, CA
    See build page.
    Yea. I thought about that as well. But i feel the amount of throttle used to push uphill then cruising down still out weighs cruising on a flat road with steady throttle especially on cruise control. Idk. maybe thats just how I see it.
  17. May 31, 2016 at 10:45 AM
    12TAG
    12TAG Member
    Then again maybe I just did something wrong? I would love it if it actually worked.
  18. May 31, 2016 at 12:03 PM
    Reaper4x4
    Reaper4x4 Member
    Beaumont, Texas
    2016 Barcelona Red TRD 4x4
    I have a 3" lift with 285/75/16 and drive flat ground and only get 17mpg driving conservatively. I will try the Navigation calibration and see how much it changes.
  19. May 31, 2016 at 4:32 PM
    Ducksman
    Brandon
    Well I got a 4 inch lift and 305 60 R18's.. You only live once, fuck it!
    marlon671 likes this.
  20. Jun 1, 2016 at 5:20 AM
    dantrd05
    Daniel
    Ottawa, ON, Canada
    2016 DCLB TRD Sport
    Pics or it didn't happen. :D:p
    :worthless:
    MadDaddy and moe2o4 like this.
