Expensive tire lesson..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MyMule, Oct 22, 2023.
  1. Oct 22, 2023 at 6:58 PM
    MyMule
    MyMule [OP] Well-Known Member
    Lowell
    Morristown, TN, United States
    2007 4.0 V6 2WD Extended cab...Pre runner
    Bigger battery..Elec in the bed..Topper,
    I recently replaced my old Michelin LTX/MS tires and went for a different look with BF Goodrich T/ A KO2's..My truck is an 07 Prerunner w/ a 4.0....I have heard alot of people complain about gear searching before..Mine started doing it for the first time with them...And the truck being known for the stiff rear end..When crossing over an expansion joint that's not smooth, the rear end could jump to the side quickly..The new tires exacerbated top speed ( of course ) , and most of all, the handling going over anything rough takes 2 hands on the wheel..Damn tires have got less than 2000 miles on them...Having Michelins mounted tomorrow...Lesson. Learned...And the cheapest way to soften the ride is to secure about 150 lbs of something in the rear..
    2015WhiteOR and BlkDakDave like this.
  2. Oct 22, 2023 at 7:00 PM
    Bishop84
    Bishop84 Well-Known Member
    E rated tires do that, but you also may be due for shocks, have you changed them in recent memory?
  3. Oct 23, 2023 at 11:15 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    As mentioned above, sounds like you got E-load tires which are very stiff and heavy, C-load tires ride significantly better and are lighter which are available for KO2s in the 17" wheel size. The trucks come with light weight and soft riding P-load tires. In terms of weight, stiffness and durability, generally speaking it goes P<C<D<E. The Tacoma is a very light truck in the world of trucks, C loads are plenty.
    JR SLASH 33 and Island Cruiser like this.
  4. Oct 23, 2023 at 11:31 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I have E load tires on my truck and they are pretty stiff when I'm at highway tire pressures. Airing down to about 15-20 psi when I'm off-road makes them smooth as butter though.
    SR-71A and Island Cruiser like this.
  5. Oct 23, 2023 at 12:03 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    what were the tire PSI, at? they installed them on my work truck, and air them up according to the tire. i lowered it down to what it says on the door jam, and it was almost normal.
  6. Oct 23, 2023 at 12:11 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    What's wrong with your truck?
    I have E tires, my back end does not "jump to the side quickly".
    YF_Ryan, ma2co and Stemmy like this.
  7. Oct 23, 2023 at 12:16 PM
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    Yeah, Michelin Defenders for the win. Despite folks best efforts, the truck was designed for P rated tires so anything else will come with a steep price in basically every department.
    I’m a guitar guy so I get wanting stuff that looks cool, but I just can’t understand buying consumable rubber for looks lol. Glad you’ve come back to the light side OP!
  8. Oct 23, 2023 at 1:08 PM
    aficianado
    back to bone stock.
    agreed 100%. i just put the M/S Michelins on my 2006 a few weeks ago. so friggen smooth and quiet. awesome offroad as well.
    i will put them on my 2023, when the time comes. works for 99% of my driving, which is on the road..so that is what i buy the tire to match (conditions)
    BlkDakDave likes this.
  9. Oct 23, 2023 at 1:09 PM
    Stemmy
    Stemmy Certified Wombat Rancher
    Rob
    Pennsylvania
    2013 Pyrite Mica DCLB
    or just slow down? I've ran E rated tires on my truck for the last 5 years and haven't had any issues.
    ma2co likes this.
  10. Oct 23, 2023 at 1:50 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I had a set of 265/75 - 16 Toyo open country mud terrain E rated tires on my 2002 Pre Runner never had an issue with driveability . Told the tire tech to only inflate them to 35 psi and the ride quality was very smooth . I had them on my truck for 25k miles no issues
    Even my 72 Camaro which has 275/ 60 -15 MT Drag radials they only have 20psi in them and these tires are almost 10 yrs old
  11. Oct 23, 2023 at 1:54 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    This is my question as well. I have had E rated tires on mine for the past 3 years or so, and never experienced this sort of description. And I don't drive like a grandma, nor was I always carrying heavy stuff in the bed...When I first got them the sprung weight of the truck was virtually bone stock minus aftermarket suspension changes and some front skids. Sure the suspension got a little unsettled at times when I had the rear springs at too high a spring rate before adding more stuff, but never would i have said the truck jumped to the side.
    i also run my tires at 40PSI, so any effects should be even more noticeable. They ride stiff but have never given me concern.
  12. Oct 23, 2023 at 1:57 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'm betting the OP was running 50+ PSI in the E rated tires. That is about right when they are mounted on a 3/4 or 1 ton truck with a curb weight of around 7000 lbs. Your Tacoma is about 2000-2500 bs lighter. If you run E rated tires on a Tacoma 30-35 PSI is plenty. Yes, they will ride stiff and not nearly as good as a P rated Michelin. But with the right PSI in the tires they aren't horrible.
    winkel, SR-71A and taco912 like this.
  13. Oct 23, 2023 at 2:06 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I've always adjusted tire pressure by using the chalk line on the tread surface trick .Draw two lines across the tread surface 180deg from ea other . Drive it around for 10 minutes then check the chalk lines on the tread surface and adjust air pressure until the chalk line is scuffed away
    I've done it this way since the early 70's and never had an issue
    knottyrope likes this.
  14. Oct 23, 2023 at 2:08 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    When my K02's were installed they put them at 40psi, I dropped them down to 34psi. And yes they are stiff but my driving habits are not your normal habits my average speed is 45-50mph. Since January I've put 3500 miles on it.
  15. Oct 23, 2023 at 2:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    E-tire user here for the last 4 years straight, never had the issue described.
    Sounds like the OP needs to work on other things like proper tire pressure and skipping KO2's indefinitely.
    TacoTyusday likes this.
  16. Oct 23, 2023 at 2:34 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've gone through numerous sets of e rated bfg a/t's over the years... love the way they track and never had a flat. E rated is a harsher ride but hell.. it's a truck. As far as loss of power never really noticed. Just switched to E rated 275/70/17 Toyo R/T's and still don't have the gear hunting you described.
    ma2co likes this.
  17. Oct 23, 2023 at 6:46 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    The cheapest way is to understand the tires and simply adjust your tire air pressure. But spend your money or haul some trash any way you think you need to.
  18. Oct 24, 2023 at 9:57 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    let me tell you after wheeling my tacoma with a set of load range E MTs airing way down was down in the teens and still had a fairly stiff sidewall. they ride rough. i daily a set in load range C and they are stiff too but not quite as bad
  19. Oct 24, 2023 at 10:24 AM
    Argann
    Argann Well-Known Member
    Rich
    4Runner, Tacoma, Defender 90
    I went from Goodyear dura to Wildpeaks. C to E rated. I run them much lower than the Goodyears. Started at 36. Now at 34. Much different. I heard some folks run low 30s with E rated. Off road I’m in the teens easy.
  20. Oct 24, 2023 at 10:31 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    KO2s don't even look that aggressive? They are basically the most common AT tire.
