Experienced Towers: Help installing Weight Dist. Hitch setup
Discussion in 'Southern California' started by nighthawk87, Apr 12, 2011.
  1. Apr 12, 2011 at 8:24 AM
    nighthawk87
    nighthawk87 [OP] Well-Known Member
    I have a 08 taco DC with factory tow pckg and will be towing my 09 Jayco Baja pop up.
    It has a front deck on it which increases the tongue weight once loaded.
    Im looking for someone that understands and wouldn't mind helping me install a weight dist. Hitch setup on my rig. I need help:
    1. Picking a comparable weight dist. hitch.
    2. Installing it
    3. Taught how to adjust it based on load.
    I'll supply the beer and lunch but I would really appreciate the help from someone so I know it's done correctly. I don't trust rv dealers.
    I'm in Lake Forest, CA.
  2. Apr 12, 2011 at 8:28 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Nothing relevant to add, but I really like those pop-ups! How heavy is the tongue weight to call for a W/D hitch?
  3. Apr 12, 2011 at 8:32 AM
    nighthawk87
    The unloaded tongue weight is only 320 pounds but after I put my crap on the deck I'm sure my tongue weight goes up. Last year the trailer pointed downwards and the truck sagged so inthink it would help.
  4. Apr 12, 2011 at 8:37 AM
    Pugga
    Massachusetts
    Something to think about, the factory leafs aren't all the strong, have you had the leaf spring TSB performed on your truck? Mine used to sit on the bump stops with a light load in the bed before I had that work done. It replaced the lighter leaf pack with a heavier duty pack. A W/D may help but may not fix the problem or be the most cost effective solution. Have you thought about an air bag set-up for the rear of the truck?
  5. Apr 12, 2011 at 8:55 AM
    nighthawk87
    I have the tsb done. No airbags though
  6. Apr 12, 2011 at 9:04 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
  7. Apr 12, 2011 at 9:10 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    Pick the proper rating for bars. Don't think bigger is better it will make the ride rougher.
