Experiencing ABS problems with lift and tires...wtf?
Discussion in 'Wheels & Tires' started by Calijavier81, Mar 13, 2011.
  1. Mar 13, 2011 at 9:06 PM
    Calijavier81
    Calijavier81 [OP] Active Member
    Puyallup, Wa.
    2011 Tacoma DblCab TRD Sport 4x4
    Stock
    Has anyone experienced a problem with their ABS after installing a lift and bigger tires?? I have a 3" lift with 285/60/18s and while on a smooth paved surface, on a declined on ramp my ABS will beep and activate...while gently "riding" the brakes. I drive this on ramp every morning so it has me concerned. Has anybody experienced anything like this? Any suggestions?
    FYI...I don't take the turn hard or slam on the brakes...it's a gradual right handed turn (on ramp) on a moderate downslope. I had no problems with my F-150 or Tacoma prior to putting on larger tires.
    Any suggestions or recommendations would be greatly appreciated...thanks in advance!
  2. Mar 13, 2011 at 9:12 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    This ^^^^ you need to get the skid control ecu recalibrated
  3. Mar 13, 2011 at 9:13 PM
    Calijavier81
    Puyallup, Wa.
    Stock
    So this is common then? Do you think they'll charge an arm and a leg to get this "reset"? It's kinda hard to trust any turns, curves, or hard braking as you can imagine. So what actually triggers the system? The "roll" of the vehicle or what?? I appreciate your quick response!
  4. Mar 13, 2011 at 9:19 PM
    Calijavier81
    Puyallup, Wa.
    Stock
    Thanks for the insight man! This should definately be part of the "read before you lift" list for noobs like me!! You put me at ease Whippersnapper! I'll get it checked out this weekend!:bananadance:
  5. Mar 13, 2011 at 9:22 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    OCEANSIDE, CA
    2016 DBL CAB 4x4TRD OFF ROAD
    6 inch Pro comp Stage 1 lift 305/70/18 MasterCraft MXT 18x9 Monster wheels,
    its like 90 bucks to fix it
  6. Mar 13, 2011 at 9:24 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Is there any way to reset it with out going to the dealer?
  7. Mar 13, 2011 at 9:28 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    Im getting the OME lift sometime next month and dont have a dealer within 120 miles of here and the only way to get to the dealer is by a 12 - 30 hr ferry ride.
  8. Mar 13, 2011 at 9:44 PM
    OZ-T
    Peter North
    British Columbia
    There is a method of resetting it on your own , I will have to find you the link when I get to a computer , I'm on my phone right now .
  9. Mar 13, 2011 at 9:47 PM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    Did you do alignment after the install?
  10. Mar 13, 2011 at 9:49 PM
    OZ-T
    Peter North
    British Columbia
    Crom has a thread about the VSC interaction , you can use the " wire " method , I would still recommend the dealer do it though .
  11. Mar 14, 2011 at 6:51 PM
    DevL
    DevL Well-Known Member
    The causes are multiple from what I have read... trying to head everyhgin off before my lift install.
    1. Tire size is not factory and the wheel speed sensors are off.
    2. VSC computer needs recalibration due to new suspension.
    3. If your rear end sits too low the VSC computer thinks you are heavily ladden and will be aggressive in preventing a loss of control.
    You can try to recalibrate your speedometer and transmisson via an intermediate device like a Dakota Digital speedo recalibrator and regearing, though that does not directly effect your individual wheel sensors.
    You can recalibrate the VSC to get a new "normal" ride angle. You can do this at home and it is supposed to be just as effective as the dealership doing it... vehilce must be on perfectly flat ground.
    You can shim your sensor in the center console to not get a tail down sensor reading.
    Thats what I have gathered so far.
  12. Mar 14, 2011 at 8:21 PM
    Calijavier81
    Puyallup, Wa.
    Stock
    Thanks for the info! Good to know..i'll be sure to get it checked out by the pros this weekend!
  13. Mar 14, 2011 at 10:39 PM
    OZ-T
    Peter North
    British Columbia
