Expert advice needed
Discussion in 'Towing' started by TacomaKiller, Aug 21, 2017.
  1. Aug 21, 2017 at 9:10 PM
    TacomaKiller
    TacomaKiller [OP] New Member
    14 TRD Sport
    I have a 2014 Tacoma TRD Sport, double cab, towing package, 3 inch lift/ level and 33 inch nitto terra grapplers.
    We just got a 2015 MasterCraft X30 wakeboard boat and I have no idea if I can tow it... it's a big boat and I don't need to tow it that far... just a few local lakes. I assume the big question would be braking power? The trailer has brakes built in. What steps should I take to try to solve this question?
    Thanks
    Michael
  2. Aug 21, 2017 at 9:11 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    What is the weight of the boat and trailer? Assuming you have a 4.0 V6, your truck is rated to two 6500 lbs
    tcjacado likes this.
  3. Aug 21, 2017 at 9:13 PM
    TacomaKiller
    14 TRD Sport
    The dry weight is 4.7k pounds. That isn't including gear, gas or the trailer weight. I'm not quite sure how much the trailer weighs. It's a standard trailer that comes with the master craft wake board boats.
    Yes, I have the 4.0 V6 with t package.
  4. Aug 21, 2017 at 9:15 PM
    tcjacado
    tcjacado Well-Known Member
    What is the weight at the tongue of the trailer.
  5. Aug 21, 2017 at 9:18 PM
    Travis1209
    Travis1209 Well-Known Member
    Travis
    2011 TRD Offroad Double Cab SB
    If it seems to be a trouble just send the boat my way, ill take it off your hands :wink:
    But..if dry weight of just the boat is 4.7k pounds, then with trailer and gear you will be essentially maxed out. Trailer brakes will help a lot. You should be just fine.
    You'll know if your towing too much. You wont feel like your in "control". Im sure it will be fine, just take it easyy
  6. Aug 21, 2017 at 9:48 PM
    TacomaKiller
    14 TRD Sport
    If I can't figure it out Travis1209 I'll be looking to get rid of it! ;) I'll check with you first.
    Based on what you said, I am guessing I need to figure out how to wire the brake controller in the tacoma.. man I am such a noob it kills me..
  7. Aug 21, 2017 at 9:50 PM
    tcjacado
  8. Aug 22, 2017 at 5:56 AM
    timothom
    Actually I think my 2014 came with some wireing harness that is the EBC if I hook it up? Or makes hooking the EBC up easier?
  9. Aug 22, 2017 at 5:58 AM
    timothom
  10. Aug 22, 2017 at 9:22 AM
    Tacoma Mike
    Southern Maine
    Yea put your stock tires back on if it's that match weight.
  11. Aug 23, 2017 at 6:25 PM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    So I did a spreadsheet (because I like spreadsheets! LOL). If the trailer weight is correct, with a full tank of gas in the boat, you have about 154 lbs left over for gear
    I have personally towed 6129 (car on a trailer with surge brakes, trailer from UHaul) and it did fine. I hardly knew it was behind me. I was able to accelerate normally and brake well (need extra room, but it wasn't horrible)
  12. Aug 23, 2017 at 7:36 PM
    timothom
    We used to tow overloaded on the farm all the time. Just don't be shy with the revs. Keep it above 3000 rpms and drive ahead of yourself a bit.
    Also having a brake controller will make it safer.
    Have fun with your new boat!
  13. Aug 24, 2017 at 3:43 PM
    ottoman
    ottoman Active Member
    Chad
    Calgary, AB
    2014 TRD Sport
    Check your manual regarding towing. It references a code on the drivers door panel to find your actual tow-able weight.
    My 2014 trd sport 4x4 dbl cab is actually only rated 6200lbs. :mad:
