expert opinion on steep cv angles needed
Discussion in 'Technical Chat' started by especk, Feb 26, 2011.
  1. Feb 26, 2011 at 4:05 PM
    especk
    especk [OP] Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    How bad are my cv angles? Am I risking damage by driving with them like this? And what kind of damage would that be?
    I am looking for people who have had coilovers set at about 3.5" and have had problems or you haven't had problems. I would like responses from people with personal experience who had cv angles similar to these.
    These angles come after installing my OME 885s with 1/2" top spacer - I'm estimating it at about 3.5".
    Thanks.
  2. Feb 26, 2011 at 4:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Those are bad. Your front is way to high.
  3. Feb 26, 2011 at 4:09 PM
    ibengineer
    ibengineer Well-Known Member
    California
    00 Tacoma TRD 4x4
    Dirt Logic 2.5" Coilovers, Camburg UCA's, Icon 3 Leaf add-a-pack, billy 5100's in the rear, Custom front Plate bumper, XRC 8500 lb winch, lots of little mods
    i have to agree ^^
    Low it about an inch and see what it looks like - or switch our your add for manual hubs.
  4. Feb 26, 2011 at 4:13 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Those 4x CV's aren't going to last long at that angle , Dump the 1/2" spacer , IFS 4x's don't seem to like anything over 3" lift.....:eek:;)
  5. Feb 26, 2011 at 4:13 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    if you are good then everyone else is definitely good:D
  6. Feb 26, 2011 at 4:20 PM
    Taco4Fish
    Taco4Fish Well-Known Member
    j
    the boot is gonna rip dirt will get inside and mess up the shafts costing $$$ to fix, just avoid the problem by lowering it an 1" or more. You probably have little down travel also.
    When I first put my toytec lift I got 3.25" lift, thought it was cool till I ripped the boots I drive through sand so it was a priority to fix. Now I lowered it to 2" just run big tires to make up somewhat.
  7. Feb 26, 2011 at 4:22 PM
    jandrews
    '09 FourDubDee TRD OR
    That's definitely too high.
    What are your hub to fender measurements? 3" lift is 23 to 23.5" hub to fender.
    Also, just FYI, it's the inner boot you have to watch the angle on more than the outer boot.
  8. Feb 26, 2011 at 4:35 PM
    especk
    Erik
    Redding, CA
    That makes me feel a little better. Thanks.
    Finally! Someone who actually ripped a boot - that's what I was looking for. I'm definitely considering lowering them now.
    My center hub to fender is almost 25". However, I have my fender flares removed so that probably adds about .5"
  9. Feb 26, 2011 at 4:45 PM
    especk
    Erik
    Redding, CA
    So why do they make the top plate spacers to go with these coils if it's just going to lead to damage? - prerunners?
    and I was hopping the Relentless bumper and winch which added about 150 lbs would help it settle more. But it hasnt seemed to do much at all yet. Should I expect it to settle more?
  10. Feb 26, 2011 at 4:46 PM
    jandrews
    Flares off, also you have a lighter truck overall, aluminum bumper, all on 885 springs. I imagine they're going to settle less over time. Whatever the reason, you're definitely higher than 3", though that may change with time.
    It'll settle more as you continue to wheel the piss out of it.
  11. Feb 26, 2011 at 6:36 PM
    especk
    Erik
    Redding, CA
    Well it looks like i'll be removing those top plate spacers sometime next week. Thanks for all the responses.
  12. Feb 26, 2011 at 6:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I think removing the top spacers is a good call .
  13. Feb 26, 2011 at 6:56 PM
    especk
    Erik
    Redding, CA
    "no dwn tapov.... no dwoen stravels.... dnows down vslwst.... no down travel!" I did it!
  14. Feb 26, 2011 at 7:00 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    If you are happy with it leave it. It's gonna have vibs / no wheel drop / and like Larry said "my cv just shit the bed"
  15. Feb 26, 2011 at 7:19 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Im pretty sure the top plate spacers are for Double cabs
  16. Feb 26, 2011 at 7:19 PM
    jandrews
  17. Feb 26, 2011 at 7:20 PM
    jandrews
    Tool.
  18. Feb 26, 2011 at 7:41 PM
    especk
    Erik
    Redding, CA
  19. Feb 26, 2011 at 7:47 PM
    especk
    Erik
    Redding, CA
    haha what is that shit??? What lift were you running at that time?
  20. Feb 26, 2011 at 7:48 PM
    jandrews
    Way overcranked Icon C/Os...
