Expired warranty on rusted out frame
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jphillips21, Jul 11, 2018.
  1. Jul 11, 2018 at 9:22 PM
    Jphillips21
    Jphillips21 [OP] New Member
    Justin
    2002 Toyota Tacoma TRD
    Anyone have any luck with Toyota on their expired warranty on rusted out frames?
    I bought a 2002 Toyota Tacoma in November 2016 via private party. Went to get new tires on it in February of 2018 and while on the lift the frame cracked in half. Frame is completely rusted and corroded over the rear tires. Called Toyota and gave them my VIN-the warranty expired on the manufacturer defect on November 11, 2017. Spoke to a supervisor and was told there was nothing they could do because the warranty is expired.
    New frame quote is $8000. Collision repair center recommends not having the frame welded as it will still be unsafe to drive in the mountains or at a high speed.
    Thanks-Justin
    alexlitvenenko likes this.
  2. Jul 11, 2018 at 9:34 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    Navigation, 10" sub, ome881 on billies 3" all-pro leaf springs with billies, taneau cover, k&n intake,axle swap with a E locker. 31" BFG A/T on KMC XD wheels, hoola girl air freshener and a broadie knob!
    Your fucked honestly. Unless you can somehow get toyota to donate you a frame.
  3. Jul 11, 2018 at 10:21 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    If you don't have the time/money/know how to find a used frame and swap it then your only real option is to part it out.. sucks man
    2002Tacoma4x4 likes this.
  4. Jul 12, 2018 at 1:07 AM
    BartMaster1234
    BartMaster1234 American Auto Horns
    Tyler
    San Francisco, California
    '98 Tacoma PreRunner 4WD / '98 Tacoma SR5 5-Lug
    2WD to 4WD Swap Power Door Retrofit '17 TRD OR Wheels
    Sorry man. There's not much you can do unless you know a good welder, or can find a used good frame out West and have it swapped.
    I'd part it out or sell it whole and cut your losses if you don't have the time or patience to fix it.
  5. Jul 12, 2018 at 1:52 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    2000 Work truck
    Super Springs
    It can always be repaired the cost might not be practical .
    If you lack the skills to do the work yourself .
    OP I am guessing the frame issues came as a surprise ??
  6. Jul 12, 2018 at 2:00 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    somewhere in the Mojave Desert
    2017 Tacoma TRD 4x4 (formerly 2002 TRD 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    A lot of clean 2002’s out here in So Cal- I sold my beloved OR DCSB 4x4 TRD SR5 (still my Avatar) 1 year ago with about 275k miles on it for $6500 and it had no rust at all - your least expensive option if you can’t fix it yourself would be to sell it and try again, but dont buy a salt belt one unless it is clean and has a new frame. Sorry about that!
    alexlitvenenko and 2002Tacoma4x4 like this.
  7. Jul 12, 2018 at 3:49 AM
    Tacomaman63
    Tacomaman63 Well-Known Member
    Stan
    2004 tacoma TRD 4x4
    step bars grille guard
    A friend of mine had a Tacoma that did the same thing, the warranty was also expired, he put it on Craigslist and sold the whole thing to a guy from New York for $3000. The guy told him since he’s from New York he’ll just weld the frame and run it
    HomePC and 2002Tacoma4x4 like this.
  8. Jul 12, 2018 at 5:06 AM
    DBowers01
    DBowers01 Well-Known Member
    Dan
    Anything is repairable if you have the know how......I just did a pretty big frame repair on a trashed 1997. Folks here told me I was nuts. Less than six weeks later it's 99% done. I have $1100 in the repairs. Could have been done for under $700 but I opted to use some new parts.
    Wyoming09 and 2002Tacoma4x4 like this.
  9. Jul 12, 2018 at 9:40 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    your only options are:
    1. Sell it for parts
    2. try to repair it if you have the skills or have a frend who does (having it done to a shop is $$$$$)
    My frame was good, but I did a major tune-up to the truck. People tell me I'm crazy too because it's an old truck. So what? All it did cost me is time because I did all the work myself. I'm very proud of this truck now :) Keep up the good work, my friend, and don't let others discourage you from finishing your project!
  10. Jul 12, 2018 at 9:55 AM
    2002Tacoma4x4
    2002Tacoma4x4 Happy Healthy Wealthy brahmakumaris.org
    C K
    Double Cab TRD off road 4WD
    4RunnerWheels Line-X
    Heck of the project you have in hands now.....
    :worthless:
  11. Jul 12, 2018 at 10:13 AM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    Firstly, I'm sure the lesson learned here is to look under the vehicle next time you buy a used car. Hell, I look under a new vehicle before buying it. That amount of rust doesn't suddenly appear in 2 years unless maybe you routinely submarine the thing in Mono Lake...
    You have either a big expensive/time consuming project on your hands, or a parts truck. If your frame is that badly rusted, most of the other bolts/hardware is probably badly rusted and worthless, too.
    Drive somewhere where they don't salt the roads and isn't coastal (no frame rust) like central CA or AZ and find a junk yard with a rolled truck of similar year. Trailer it home and make the swap.
    You could always trailer the truck home as is, and throw some rebar on the frame and booger weld the crap out of it. Seen that done before - not that I'd ride in one like that, though... Even if you could adequately repair the broken section, the rest of the frame is likely just as bad, and not too far off from a similar failure. So unless you can get INSIDE the boxed frame sections and clean/repair the rust there, too, dump the frame and find a rust free donor for the desert.
  12. Jul 12, 2018 at 2:51 PM
    OnHartung'sRoad
    Not the OP’s, but its never a pretty picture when one discovers this issue for the first time when its loaded on a lift
  13. Jul 12, 2018 at 7:41 PM
    DawsonDestroyer
    DawsonDestroyer Well-Known Member
    Dawson
    Oklahoma City, Oklahoma
    2002 Tacoma Prerunner Double Cab
    Man that sucks
  14. Jul 12, 2018 at 8:46 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Really a bummer. Not much you can do about it though but either dump it or get ready to spend a lot of money! Someone should get into the business of fabricating aftermarket Tacoma frames, probably make a killing! There's companies that do them for Jeeps because stock Jeep frames are wimpy and they've turned into multi million dollar industries. If I knew anything about welding, I'd be all over this.
  15. Jul 12, 2018 at 8:49 PM
    2004TacomaSR5
    Jon
    Montana
    Not just Tacoma, but Tundra/Sequoia, older Pickup/Hilux and 4Runner frames as well as they've also suffered from the rust problem too.
  16. Jul 12, 2018 at 9:28 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    It's the bending tooling that would be expensive.
    OP, frames can be found but we have no idea where you live. Maine? Hawaii?......Siberia?
