Explain why the 4x4 and 4x2 would not get the same mpg until you switch to 4x4?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by volcop, Sep 20, 2015.
  1. Sep 20, 2015 at 6:26 AM
    volcop
    volcop [OP] Well-Known Member
    2012 Tacoma TRD Offroad
    none
    You would think they would get the same mpg, maybe because the 4x4 is a little heavier or geared different.
  2. Sep 20, 2015 at 6:27 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    More component's to turn, more load on the engine
    12TRDTacoma and Jeffvt0508 like this.
  3. Sep 20, 2015 at 6:51 AM
    Ndanger
    Ndanger Active Member
    Hawaii
    08 Tacoma 4x
    Front axle drag seems like the biggest issue imo. I assume that it is because the days of getting out in the mud to turn the front hubs to the lock position have given way to the convenience of running the front axle full time.
    My first regret that front hubs are no longer part of the deal is that when I tow up a steep hill on pavement it would be nice to use low range and not have the front tires engaged on hard surface. Also the hit that mileage takes is huge...
    Then again I do not know if this new generation runs the front axle continuously but I assume so...
  4. Sep 20, 2015 at 6:53 AM
    DJP
    DJP Member
    Idaho
    07 TRD OR DCSB
    Weight also makes a difference.
  5. Sep 20, 2015 at 7:04 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    weight makes a big difference.
  6. Sep 20, 2015 at 7:10 AM
    Ndanger
    Hawaii
    08 Tacoma 4x
    Does anyone know what the weight difference is 4x2 vs 4x4?
  7. Sep 20, 2015 at 7:53 AM
    TacOffRoad11
    TacOffRoad11 Well-Known Member
    Josh
    Georgetown, KY
    '18 F150 XLT
    This is based off the 2015s but a 4x2 Prerunner V6 DCSB curb weight is 3985. The same truck in 4WD is 4220.
  8. Sep 20, 2015 at 7:55 AM
    TacOffRoad11
    Josh
    Georgetown, KY
    '18 F150 XLT
    Again on the 2015s, but a 2wd access cab 4 cylinder 5 speed comes in at 3615 pounds and a 4wd access can 4 cylinder 5 speed weighs in at 4030 pounds.
  9. Sep 20, 2015 at 8:02 AM
    SDTaco4x4
    SDTaco4x4 Well-Known Member
    San Diego
    2016 Black TRD Sport 4x4
    Wait, how does it add only roughly 200lbs in the V6 but almost 400lbs in the 4banger access cab?
  10. Sep 20, 2015 at 8:04 AM
    TacOffRoad11
    Josh
    Georgetown, KY
    '18 F150 XLT
  11. Sep 20, 2015 at 8:17 AM
    Ndanger
    Hawaii
    08 Tacoma 4x
    Front Diff, transfer case, drive line, front half shafts et al I expected to be in the 350 to 400 lb range so 200 lbs seems low although I am not complaining if that is the case.
  12. Sep 20, 2015 at 8:17 AM
    TRDPro4x4
    TRDPro4x4 Well-Known Member
    2016 4x2 vs 4x4 is approx 250lbs depending on model.
  13. Sep 20, 2015 at 11:09 PM
    Ndanger
    Hawaii
    08 Tacoma 4x
    Getting back to the mileage issue, how much would you expect the weight (similar to 1.5 to 2 passengers) effect the gas mileage and do you think the weight is the main reason for the difference?
  14. Sep 21, 2015 at 12:53 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Probably the simple answer is because no one should trust the weight numbers on the web for Toyota, they all typically refer to some fictitious configuration they build two units a year of...
    But my guess would be that in the comparison made I think for the I4 it is a 5 lug vs a 6 lug while for the V6 it is 6 lug vs 6 lug. The I4 comparison is probably picking up the extra 200 lbs in moving from a 5 lug suspension to a 6 lug - but I could be wrong about whether that I4 configuration is a 5 lug or not.
    EDIT: Indeed - if I change the comparison on the I4 to be with an AT so that we can do a 4x2 prerunner to 4x4 comparison the weight difference is now just 240 lbs. If I leave it at AT and select the 4x2 to not be a prerunner then we go back up to a 400 lb difference. I'm going with the original comparison for I4 was 5 lug 4x2 against 6 lug 4x4.
  15. Sep 21, 2015 at 1:16 AM
    DVexile
    Ken
    Well it depends on whether you are talking highway or city, but we can make an estimate using an online calculator.
    Using this site:
    http://ecomodder.com/forum/tool-aero-rolling-resistance.php
    And putting rough figures similar to a Tacoma:
    4000 lbs, Crr .011, Cd 0.4, A 30 sq ft, and defaults for the rest of the values we get 20.31 mpg at 65 MPH with drag being 75% aero drag (which would be independent of weight). So likely the difference for 200 lbs is not a lot. Lets try...
    Same parameters as above but weight at 4200 lbs gives us 20.06 mpg at 65 MPH. So for highway, essentially little or no change. But of course for city things would be more complicated since you are accelerating that additional mass a lot rather than just dealing with a minor increase in rolling resistance from the weight.
    Fortunately this is a question lots of people have had, and some Googling will get you this study:
    http://www.drivealuminum.org/research-resources/PDF/Research/2008/2008-Ricardo-Study.pdf
    Which on page 29 has the results for weight reduction on a vehicle very roughly similar to a Tacoma (its a more efficient small SUV but of the same chassis weight as the Tacoma). There a 200 lbs increase in weight took city mileage from 21.2 to 20.9. Looking across multiple other vehicle configurations in the study that's usually about the size of it, 200 lbs will change mileage by about 0.3 MPG for vehicles getting similar mileage to the Tacoma.
  16. Sep 21, 2015 at 2:00 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Weight
  17. Sep 21, 2015 at 3:38 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    +1, but difference is small. My current Tacoma gets the same MPGs as my 2009 Prerunner. Even in the old days with locking hubs MPGs were lower due to weight and drag.
  18. Sep 21, 2015 at 4:43 AM
    nv529
    nv529 Well-Known Member
    Nick
    Metro Detroit, Michigan
    2006 Long Travel Taco, 2010 FJC, 2018 F250 Alumiduty
    2015 2nd gen specs per toyota build site PDF's
    5-lug axle 2wd AC 2.7L weight: 3615
    6-lug axle (prerunner) 2wd AC 2.7L weight: 3810
    4x4 AC 2.7L weight:4050
  19. Sep 21, 2015 at 5:14 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    You are turning an extra gearbox (transfer case) in the 4x4 and pushing the CV axles. I just got finished converting my truck to 4x4. There is a huge difference in how easy the wheel spins without the CV axles installed.
    But having said that, I still get exactly the same gas mileage as before my conversion.
  20. Sep 21, 2015 at 5:18 AM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    This is a question? Is there no science before posting?
