Explaining 4LO
Discussion in '1st Gen. Tacomas (1995-2004)' started by montanabay, Jun 7, 2010.
  1. Jun 7, 2010 at 8:34 AM
    montanabay
    montanabay [OP] Active Member
    CA
    2.7L 4WD AUTO
    Hi All,
    I have a 1995.5/6 Tacoma, 2.7L 4WD Auto with the A340F transmission with manual 4WD.
    My first car was a Jeep CJ, had a manual transmission, also with manual hubs (all around). The CJ had a locker in the back, which I always used in 4LO. With this I could shift through all the primary gears, giving me 5 ranges in LO, which was quiet handy.
    My question is how does the 4LO work in my auto Tacoma? I haven't used it much, mostly because it seems to be mono-gear, rpms max out 2-3mph, which is fine to the "stuck" situations, but for pulling people from ditches etc, I found that 4HI is better, because even though I get more slippage, I can get more momentum overall, vs the 4LO crawl.
    Thanks!
    Josh
  2. Jun 7, 2010 at 12:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Josh, are you saying that when your 4wd lever is in the 4lo position and your shifter lever is in the "D" (drive) position, the truck will not shift out of first gear and is limited to 2-3 mph? Do you have a tachometer? How high are the RPMs in these conditions?
  3. Jun 7, 2010 at 12:36 PM
    montanabay
    CA
    2.7L 4WD AUTO
    yup, she whines like crazy and must stay in 1st, @ 3-4mph she sounds like she's about to put a rod into space.
    no tach, which is really frustrating
  4. Jun 7, 2010 at 12:38 PM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    no it'll shift once it hits ~4k
  5. Jun 7, 2010 at 7:46 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    mine shifts, i hardly ever use 4 hi unless im mud riding.
