Ext. Length Icons... who sells them?
Discussion in 'Suspension' started by ETaco23, Aug 13, 2010.
  1. Aug 13, 2010 at 9:47 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Ive been searching all day for tem. And just now I found out that Domello sells them for the 05+. Who else is there?
    Just doing some research. :D
  2. Aug 13, 2010 at 9:50 PM
    SKINUM
    SKINUM Well-Known Member
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    Demello, Metaltech, Ironpig, Budbuilt, Toytec.......probably more as well.
  3. Aug 13, 2010 at 9:51 PM
    ETaco23
    Evan
    PNW
    Awsome! thanks a bunch.
  4. Aug 13, 2010 at 10:00 PM
    ETaco23
    Evan
    PNW
    Do the ext. length one's also give up to 3.5" o lift? or is that only the regular one's?
  5. Aug 13, 2010 at 10:02 PM
    SKINUM
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    Both
  6. Aug 14, 2010 at 6:54 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    wheelers sells them too
  7. Aug 14, 2010 at 6:56 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    if your getting a 4WD truck your not gonna be able to get anywhere near 3.5" lift out of the CO's...
  8. Aug 14, 2010 at 10:50 AM
    ETaco23
    Evan
    PNW
    I know. But Im hoping to get them close to 3.25" without issues. I wish I could not get a 4wd, but its a must have here in the NW. :( that way I can run a 4" spindle lift, with Icons. :)
  9. Aug 14, 2010 at 10:58 AM
    Beast
    Beast Well-Known Member
    Mark
    Slc,Utah
    2010 4x4 SR5
    grillcraft, tinted windows, HID's, Magnaflow exhaust, tsb, Icon ext. coilovers,camburg uca's, oem bedmat, 5100s in rear, wheelers aal, 275/65R18 duratracs, 18x9 kmc monsters
  10. Aug 14, 2010 at 11:10 AM
    offroad
    offroad Member
    west
    08 TRD 4X4
    try outlaw offroad
  11. Aug 14, 2010 at 1:37 PM
    ETaco23
    Evan
    PNW
  12. Aug 15, 2010 at 5:38 PM
    SKINUM
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    Did u call or send a PM? I sent a PM but haven't gotten a response.
  13. Aug 15, 2010 at 10:35 PM
    ETaco23
    Evan
    PNW
    sent a PM. and he was on, so he responded in like 2min.
  14. Aug 16, 2010 at 12:39 AM
    SKINUM
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    Hmm, not sure whats going on then. It's been a few days so maybe I will send another PM over.
  15. Aug 16, 2010 at 1:04 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
    SKINUM...got your PM on Saturday. I need to get back to you tomorrow. The OPs was much simpler than yours. He was just asking for a set of COs. I need to look at our price sheets (at the shop)for your goody list, because I don't know all that stuff by heart. I will get your quote to you by the end of the day tomorrow, when I'll be back in the office. Thanks.
  16. Aug 16, 2010 at 1:35 AM
    SKINUM
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    Appreciate the info!
  17. Aug 16, 2010 at 7:52 PM
    ETaco23
    Evan
    PNW
    There basically the same. I think its internal, that gives the extra travel.
  18. Aug 16, 2010 at 8:25 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Extended Icons from downsouth soon to be on order...YAY...:D
  19. Aug 16, 2010 at 9:06 PM
    Hi everyone,
    Figured I would chime in and give my 2 cents.You should be able to tell by the extended length of the shocks.ICON has a shock drawing and they can give you the specs between the 5-8630 and the 5-8635.The extended travel will usually allow for 1.5"to 1.75" of more wheel drop out. Shock travel and wheel travel are 2 different things and motion ratio plays a part.
    I would give ICON a shout and they can get you the dimensions from the mounting plate to the center of the lower mounting eyelet (Rod End)
    See ya,
    Sonny
  20. Aug 16, 2010 at 9:09 PM
    Most shock companies will use an internal shaft spacer between the seal assembly and the valve body to limit the extended length.
    Ext. travel shocks will either have the spacer removed, depending on the shock set up.Having a smaller internal spacer or not one one at will allow for the shaft to extended further out of the shock, this giving it more droop travel and the use of an after market UCA's is a must.
    Hope this helps.
    See ya,
    Sonny
