Extend the frame
Discussion in '2nd Gen. Tacomas (2005-2015)' started by unibug, May 10, 2013.
  1. May 13, 2013 at 6:15 PM
    unibug
    unibug [OP] Member
    Oregon
    1-ton with utility box's
    Self made utility box's
    I have modified my Six Pac and it weighs about 1000 lb. loaded. I have added Air bags to the rear suspension and have not had any problems in 15 years. My current truck is 3.0 V6. It can haul a grade and maintain 55 mph. My understanding is that the 3.4 and the 4.0 V6 have a much better power to weight factor. It should preform better than what I have now and get better mileage.
    I haven't calculated what my camper design will weigh yet. I am hoping for around 1,000 - 1,200 lbs.
  2. May 13, 2013 at 6:52 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    A frame splice is doable, similar to how AEV makes Jeep Wrangler pickup conversions:
    However, the Tacoma frame is double-walled, riveted together, so you will need doublers inside and outside.
    Longer driveshaft is relatively easy - just measure the distance between flanges and order a custom one-piece from http://www.4xshaft.com/ Then you will need to extend brake lines and wiring.
    Other unknown but possible effects include VSC misbehaving due to the longer wheelbase.
  3. May 14, 2013 at 8:19 AM
    unibug
    unibug [OP] Member
    Oregon
    With the camper on it is somewhere between 13 and 14 mpg.
