Extended axles for 4" lift?
Discussion in 'Suspension' started by 05Taco4x4, Apr 26, 2020.
  1. Apr 26, 2020 at 8:31 AM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    A friend says he has a 4" suspension lift and 1" diff spacers, should he be using extended axles?
  2. Apr 26, 2020 at 9:31 AM
    05Taco4x4
    2TR-FE Enthusiast
    Effectively, does he need extended axles for a 3" lift?
  3. Apr 26, 2020 at 9:36 AM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Why would He. Just effectively dropping the suspension.
  4. Apr 26, 2020 at 9:42 AM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    No
  5. Apr 26, 2020 at 9:45 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
  6. Apr 26, 2020 at 9:56 AM
    05Taco4x4
    2TR-FE Enthusiast
    I find it hard to believe it doesn't increase the distance between the two joints of the CV on a 3" lift.
  7. Apr 26, 2020 at 10:00 AM
    05Taco4x4
    2TR-FE Enthusiast
    But apparently not enough to matter, I've read the same. Thanks guys!
  8. May 1, 2020 at 4:28 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Is the 1" spacer necessary for the 3" lift? IF not technically necessary, should it be used anyway to minimize angle? I ask because I plan on 2.75-3" lift in front and want to get all the necessary bits at the same time.
