extended brake line 05 2.5” lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Diabl0, Apr 22, 2022.
  1. Apr 22, 2022 at 8:17 AM
    Diabl0
    Diabl0 [OP] 2005 TRD Off Road DC SR5
    Tim
    Massachusetts
    2005 TRD off Road DC SR5
    AUCar Android Stereo Bluetooth Katskin Leather Soft Bed Cover Dual kicker comp s10’s Bull bar Euro headlights Black grill Clutch bypass switch Alpine 6.5 and 6x9 speakers Kicker Subaru Tweeters Diamond floor mats Dick Cepek DC2 Wheels Toyo Open Country ATII Tires Black Aftermarket Grill Rhino lined Tube Side Steps Back up Camera
    Do I need extended break lines for my lift? I’m doing a 2.5” ome lift. If so can you link me to the correct ones please
  2. Apr 22, 2022 at 9:25 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I didn’t get any for mine.
  3. Apr 22, 2022 at 9:30 AM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    If you get the rear nitro shocks then no you dont
  4. Apr 22, 2022 at 11:17 AM
    Diabl0
    Tim
    Massachusetts
    Thanks guys
  5. Apr 23, 2022 at 5:47 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I got the Headstrong Offroad kit... 1" extended front/4"back made by Crown. Have extended travel front/back and the RXT leaf pack which has additional droop travel... truck is around 2.5" lift front and back. One thing to check out... raise the front to full droop and turn the wheels to full lock. On mine the oem brake line is stretched to the max.
  6. Apr 23, 2022 at 6:12 PM
    Dalegribble02
    The ome kit isn't extended travel and his shocks have internal stop in them he don't need brake lines. I used to have the kit he had
  7. Apr 23, 2022 at 6:54 PM
    Diabl0
    Tim
    Massachusetts
    What else did you do other than needle pin and Carrier bearing drop?
  8. Apr 23, 2022 at 6:59 PM
    Dalegribble02
    I only did the ecgs bushing in the front diff. Didn't do anything to he carrier bearing I never got vibes there.
  9. Apr 23, 2022 at 6:59 PM
    Bishop84
    Bishop84 Well-Known Member
    You don't really need it.
    But bend the ABS harness bracket down a bit to compensate for the lift. It comes from the upper strut and works its way down the knuckle.
    Also in the rear, bend the bracket that bolts to the leaf spring that holds the ebrake, it has a lot of tension when lifted.
  10. Apr 23, 2022 at 7:05 PM
    Diabl0
    Tim
    Massachusetts
    Thanks guys
