Extended brake line replacement, need some help.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taconator_, May 12, 2019.
  1. May 12, 2019 at 7:25 PM
    Taconator_
    Taconator_ [OP] IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Ok so I’ve taken apart and rebuilt engines and transmissions, but I’ve never done brake lines. I almost feel dumb asking for help but I’m somewhat afraid of messing this up. Does anyone have any videos or something I can reference to so I don’t crash and die lol.
    It doesn’t seem too difficult, I have a 10mm flare nut wrench which should be the size? but I’d like a good step-by-step video?
  2. May 12, 2019 at 8:55 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    I replaced my 4 lines, very easy job. Actually a hard job due to tight space but very easy in essence.
    Check Y/T lots of videos.
  3. May 12, 2019 at 8:57 PM
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    If I only replace the rear, do I still have to bleed all 4?
  4. May 12, 2019 at 9:00 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I would bleed all 4. I have no experience with this specific job however.
  5. May 12, 2019 at 9:05 PM
    DIRTT_Fish
    DIRTT_Fish Well-Known Member
    2017 TRD OR DCSB
    Cbi t3, 888, HD Dakar, b110, wheelers bumps,ubolt flip, spc uca, +4" rear brake lines.
    I bled all four just in case, barely took any time. Theres a YT video of a fj cruiser I used for reference.
    If you're somewhat mechanically inclined this is really a no-sweat install. I never have done brk lines in my life either and it was a cake walk.
    Have things prepped. Tools in arms length. I took the spare out for more room. Towels or rags to catch the dripping fluid. GL
  6. May 12, 2019 at 9:15 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Always helping the community man. Thank you
  7. May 12, 2019 at 9:17 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I’ve done a few. You’ll want to bleed all 4 just in case. The tiniest air bubble will give you squishy pedal and reduced confidence in your brakes. There’s ways to bleed you brakes by yourself (with and without special tools/bleeder pumps) but it’s just plain easier with a second person. You’ll want to bleed from the furthest away from the master and work your way to the closest- rear passenger, rear driver, front passenger, front driver.
  8. May 12, 2019 at 9:22 PM
    GHOST SHIP
    GHOST
    Also as a heads up, the rear brake lines are side specific and depending on where you buy your lines from the new set will have different fittings for their specific side. It’s a minor difference in the mounting flange, but you should see the difference immediately once you take a close look at the new lines. At quick glance they’ll look the same. IIRC, the “hexagon” fitting goes on the passenger side.
    Also the top nut for the rear brake lines is a bitch and a half to get to so I’d start with those to get any potential frustrations out of the way early.
