extended brake line
Discussion in 'Suspension' started by BAMFTACO, Aug 26, 2010.
  1. Aug 26, 2010 at 6:42 PM
    BAMFTACO
    BAMFTACO [OP] Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I have a three inch lift and my brake feel alittle mushy only if I brake hard or if I go over bumps and I was wondering if extended brake lines would help fix that and any input would help.
  2. Aug 27, 2010 at 2:52 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Yea the tacos are known for loose brakes. Try flushing the lines and adding stainless steel brake lines
  3. Aug 27, 2010 at 3:06 PM
    BAMFTACO
    Juan
    Kings bruh
    Alright and how much do the stainless steel lines cost
  4. Aug 27, 2010 at 10:14 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    A set of 3 (2 front, 1 rear) will run you ~$90 at 4wheelparts. Def worth it.
  5. Aug 27, 2010 at 10:19 PM
    BAMFTACO
    Juan
    Kings bruh
    Thanks and are the lines extended or just replace the stock with new ones
