extended brake lines for lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MotoXdoer, Sep 25, 2009.
  1. Sep 25, 2009 at 11:28 AM
    MotoXdoer
    MotoXdoer [OP] taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    are they required in the process of adding a lift 0-3" or a good upgrade?
  2. Sep 25, 2009 at 11:54 AM
    09blacktaco
    09blacktaco Well-Known Member
    The Rockies
    09 DC 4x4 TRD OR
    prob a good idea but not required. i have plenty of length in the front, but the rears are stretched pretty tight at full flex.
  3. Sep 25, 2009 at 12:29 PM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    the are not REQUIRED for anything 3" or under but i would definitely without a doubt add them anyway for multiple reasons. first of all, get braided stainless lines and your braking will be less "mushy" cause the lines wont bulge. not a big deal but kind of cool. secondly, if you are doing any offroading, when you flex if your lines are too short they can brake lose, losing all pressure. you would probably be safe not changing them, but if you are on a 20 to 30 degree incline on the side of a mountain do you really wanna find out your factory lines are too short? they are easy to put on and relatively cheap ($50-$60) compared to other lift components. my opinion is not to go cheap or cut corners when you and your truck are involved
  4. Sep 25, 2009 at 12:32 PM
    nd
    Nate
    Greenville, SC
    yeah, there is less play in the rear lines. i replaced those but as of now i only have a 2.5 on the front and the lines are pretty long so i didn't replace them. i will in the future when i upgrade my front suspension again
  5. Sep 25, 2009 at 12:32 PM
    nd
    Nate
    Greenville, SC
    just out of curiosity, what kind of set up are you planning on going with?
  6. Sep 25, 2009 at 12:55 PM
    MotoXdoer
    Nate
    San Luis Obispo, Ca
    icon c/o front and rear AAL with icon rear shocks
  7. Sep 25, 2009 at 1:05 PM
    nd
    Nate
    Greenville, SC
    ok, so you're actually putting some money into your suspension. if you're already spending some cash you might as well spring for the lines. at least for the back. but personally i'd get them for front and back. you're already under the truck getting dirty, you might as well do it all at once
