Extended Brake Lines/ Proportioning valve questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Voos, Jul 9, 2009.
  1. Jul 9, 2009 at 11:28 AM
    Voos
    Voos [OP] Well-Known Member
    Eric
    Albuquerque, NM
    Dbl Cab SB TRD Off Road
    Icon CO's, Total Chaos UCA's All-Pro 3" leaf packs w/ U bolt flip +Timbren, Rear Bilstein 5100's, Dick Cepek DC1's Black, 285/70R17 BFG ATko, ProDryS drop in, Dynomax Super Turbo
    Looking to lift my 09 double cab. I have a set of Deaver 10 leaf for the rear and I am curious if longer brake lines are a necessity..??
    Also is it necessary to re mount the proportioning valve??
  2. Jul 9, 2009 at 11:31 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Welcome to TW.
    Longer brake lines are always a good idea with and/or longer travel suspension. As for the proportioning valve, do you have any pictures?
  3. Jul 9, 2009 at 11:44 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'm not sure how the new trucks are setup.... but the 1st gen trucks, you had to raise the BPV bracket up the same amount as your lift amount.
    I did some quick searching, and it looks like the 2nd gens (05+) don't have one (and /or its completely different).
  4. Jul 9, 2009 at 11:46 AM
    mjp2
    NJ
    That's why I wanted to see some pictures. If we have a proportioning valve I want at that thing! The only thing I've found is the massive ABS unit under the hood on the passenger side by the firewall.
  5. Jul 9, 2009 at 1:32 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    if you are just putting the deavers on, then you dont need any lines or moving anything.You will need a longer rear shock tho. I did the same and no problems. You might need a axle shim or carrier bearing drop if you develop a vibration. I put a 2 degree steel axle shim in and it smoothed out some driveline vibration.
  6. Jul 9, 2009 at 3:02 PM
    Voos
    Eric
    Albuquerque, NM
    Thanks for the quick responses guys!
    I was unaware there was no BPV.. I haven't crawled under it yet..
    So.. Longer brake lines= good but not a necessity..
    Now I just need to decide what rear shocks to go with.. Icon res are twice the price of the 5100's... I'll probably never do anything extreme enough to require the Icons but they sure are shiny!
  7. Jul 9, 2009 at 5:33 PM
    Voos
    Eric
    Albuquerque, NM
    recommendations??
  8. Jul 9, 2009 at 5:51 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    OME is good stuff...I'm very happy with mine so far.
    Wheelers Offroad has everything I needed for my lift...Lines, Shocks, and all the hardware and what not.
  9. Jul 9, 2009 at 6:35 PM
    Voos
    Eric
    Albuquerque, NM
    bump
