Extended brake lines...when are they needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cappy, May 19, 2022.
  1. May 19, 2022 at 6:26 PM
    Cappy
    Cappy [OP] Well-Known Member
    Georgia
    Can anyone tell me at what point extended brake lines are needed? Is there a certain amount of lift where the stock lines are too short? Looking at going up 2 inches front and rear and was curious if anything will need to be done to the lines. TIA
  2. May 19, 2022 at 6:36 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I did Deaver Stage 2 and at full droop OEM hoses are not taught.
  3. May 19, 2022 at 6:56 PM
    Cappy
    Georgia
    How many inches of lift did you get?
  4. May 19, 2022 at 8:57 PM
    eurowner
    eurowner Duke Sky
    Scoty
    About 2.5"
  5. May 20, 2022 at 3:01 AM
    Cappy
    Georgia
    Gotcha thanks
  6. May 20, 2022 at 3:09 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Do you plan to take it off road ever -- Yes -- Change them its easy and cheap.
    No never -- leave the stocks
    One of the worst feelings on the trails is when you are broken down waiting because of a simple solution you decided to neglect.
    eurowner, 71tattooguy and c_walters like this.
  7. May 20, 2022 at 4:27 AM
    Cappy
    Georgia
    Good point. May do some mild offroad but nothing crazy. Thanks
    ClassyTacos[QUOTED] likes this.
  8. May 20, 2022 at 4:39 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The limiting factor on a stock rear end is your shocks. Any shock that has a ~24" or less extended length won't need new brake lines. Once you start getting into higher amounts of lift/want more flex from the rear and need longer shocks, then you'll need new brake lines.
    Some examples:
    OME Dakars and Bilstein 5100s - stock brake lines
    Deavers and Kings - stock brake lines
    Icon RXT and Bilstein B110 - +4" brake lines because the B110 are longer and allow for more flex
    Deavers and a shock relocation with 12" shocks - +4 or greater brake lines because they're longer and allow for more flex
    Hopefully that clears things up.
  9. May 20, 2022 at 4:52 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I looked up the Ironman FCP rears and they are 610mm extended length, so 24.016” extended length. While I know I’ve had one side off the ground while off-roading and it didn’t snap the line, maybe I should still reconsider extended lines as well.
    Thanks for this @EatSleepTacos great info.
    EatSleepTacos[QUOTED] likes this.
  10. May 20, 2022 at 4:58 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Extended lines are never really a bad idea. I put a set of +6" on a friend's truck recently and just due to how they're designed and their flexibility, there's really no risk of getting them snagged on something from being too long or anything of that nature. It looks nice and you get braided stainless steel, but you don't necessarily need them with that setup. That said, we've all bought plenty of stuff we don't necessarily need but still want. My truck may be the worst offender.
  11. May 20, 2022 at 5:02 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    I’ve never bought anything I didn’t necessarily need for my truck… well, maybe besides the actual truck and everything that’s not gas :rofl:
    I’ll add these to my list of things!
  12. May 20, 2022 at 5:27 AM
    Cappy
    Georgia
    Good info. I have an Eibach pro stage one kit to install so I would assume that because of the length limit I wouldn't need to extend the lines.
  13. May 20, 2022 at 5:48 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I have this lift and with the rear end completely off the ground at full down flex, there is plenty of brake line left. The parking brake cables....those are a different story.
  14. May 20, 2022 at 6:13 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's correct, your shocks would be the limiting factor so your brake lines would be fine.
    I ended up having to remove the bracket that holds the parking brake line to the leaf. Luckily the line doesn't rub on the leafs very bad but if it gets worse I'll wrap it with another rubber hose to act as a sacrificial layer.
  15. May 20, 2022 at 6:21 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Just have to ask, have you checked the drivers side leaf saddle bolt to make sure the threaded end is not digging into the fuel tank? They had a batch of them the the bolts were put in the wrong way.
  16. May 20, 2022 at 7:01 AM
    airforceb2cc
    Don
    KCMO
    Everything looks good on mine.
    hyrule_trd[QUOTED] likes this.
  17. May 21, 2022 at 6:25 AM
    AJ4mPR
    AJ4mPR Well-Known Member
    AJ
    2019 Tacoma TRD OffRoad DCLB Quicksand
    I would say, when you lift your truck by the frame, and drop the rear axle completely (might need to remove rear tires),,,, if your lines are stretch or tight,, then you should consider it. Worst thing that could happen is that you are on the trial and it over extends and you loose your rear breaks completely.... if you are on road only, i would not worry about it. (keep stock lines in a ziplock bag in your trail repair kit for emergencies)
  18. May 21, 2022 at 6:35 AM
    Cappy
    Georgia
    Two really good points.
  19. May 21, 2022 at 7:12 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I went extended on my 2nd gen mainly because of the extended travel front coilovers/rear shocks and rxt leafs. Got the Tacoma package from Headstrong Offroad (Crown lines... 1" front & 4" rear.)
    Check the front lines at full droop/full lock... my oem lines were stretched bad after the lift... 1" extended gave some slack.
  20. May 21, 2022 at 10:22 AM
    Barcelona21Taco
    Barcelona21Taco Well-Known Member
    21 OR
    My truck is raised 3 inches in front and 2 inches in back but I don’t know about the brake lines. I will be doing some testing soon it sounds like. Thanks to all.
