Extended Brake Lines when Lifting Truck
Discussion in 'Suspension' started by Built4TheHunt, Apr 11, 2022.
  1. Apr 11, 2022 at 4:11 PM
    Built4TheHunt
    Built4TheHunt [OP] Bass Fishing and Bowhunting...
    Gavin
    Downstate Illinois
    16 QS DCSB TRD OFFROAD
    I don’t know if this belongs in the suspension forum, but I think it’s relevant. I’m lifting my 3rd gen with a 6/5 setting Bilstein 6112’s and RTX Leaf Pack in the rear w 5160’s.
    My question is: Will I require extended brake lines? The Lift is going to be approx 2.5”
    thank you
  2. Apr 11, 2022 at 4:19 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Rear definitely recommended but some of that depends on how the truck is driven.
  3. Apr 11, 2022 at 9:29 PM
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    They'll most likely be tight but not tearing out, I have never liked it and now I'm upgrading to the Yotamafia lines.
  4. Apr 11, 2022 at 10:41 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Any bolt in rear shock typically maxes out before the brake lines start to pinch.
  5. Apr 12, 2022 at 9:11 AM
    o313
    N
    2018 DCLB AT SC
    Correct but its definitely doing a little stretch and thats not going to extend its lifespan.
  6. Apr 12, 2022 at 9:17 AM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    What I do if people don't have extended lines, is bend the tabs that the soft/hardline connection meet up to so those connections actually face themselves a little more. Easily gains another ~1-2" of brake line travel.
    o313 likes this.
  7. Apr 12, 2022 at 9:20 AM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    5160 kit for brake line spacer is provided with drivers side shock. I have Deaver 402 stg 1 which provids a 2 inch lift. Works as designed by Bilstein.
    Built4TheHunt[OP] likes this.
  8. Apr 16, 2022 at 7:14 AM
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    I did wheelers +2” lines in the rear, going to bend the mounts to gain a little more also.
    33yrsoftoys likes this.
  9. Apr 16, 2022 at 8:29 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Quick question... do aftermarket bumpstops (just installed Timbren) help keep the brake lines from stretching? Got about 3" between the bumpstop and frame now (RXT leaf pack at option 2.)
  10. Apr 16, 2022 at 8:37 AM
    o313
    N
    2018 DCLB AT SC
    I don't run the Timbren but I would guess that they do limit travel a bit and would help prevent the stretch of the stock lines.
  11. Apr 16, 2022 at 9:11 AM
    rnish
    Tacoma 2nd gen
    Bumpstops deal with compression (stopping up travel so the shocks are not the up limit {stops}). The extended brake lines deal with down travel.
    JFriday1 likes this.
  12. Apr 16, 2022 at 9:14 AM
    o313
    N
    2018 DCLB AT SC
    Good point
  13. Apr 16, 2022 at 9:26 AM
    OffroadToy
    So stopping the up travel on the passenger side would cause less down travel on the driver side... correct? :confused:
  14. Apr 16, 2022 at 10:24 AM
    rnish
    Tacoma 2nd gen
    A stock truck has a real world ~8” of travel. You can be at the upper limit on one side and lower limit on the other. People remove their sway bars to get a little more flex out of the IFS. Regardless you don’t want the shocks being the hard limit on the up or down stroke.
  15. Apr 18, 2022 at 11:29 AM
    OffroadToy
    As far as the front some say longer lines aren't needed for a 2" lift. Just checked mine (extended coilovers set at 2" lift height) at full droop with the wheels at full lock and the oem lines are stretched to the max.... just something to check out.
