Extended brake lines
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rainyben45, Apr 20, 2020.
  1. Apr 20, 2020 at 10:18 AM
    rainyben45
    rainyben45 [OP] Well-Known Member
    Ben
    Ventura County
    2018 TRD OR DCSB 4x4
    Hey TW folks,
    I’m installing extended brake lines with my heavy duty leaf springs next weekend and was wondering if anyone with a 2016+ Tacoma could chime in on their experience bleeding the brakes after installing them?
    Thanks!
    CBrob likes this.
  2. Apr 20, 2020 at 10:21 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    With an OR it is stupid stupid easy. Once you install them, turn your truck to "on" without starting the truck. If you're push to start, that means push the button twice but leave your foot off the brake.
    Then, apply pressure to the brake pedal and keep pressure on. Crack open the bleeder. The electric pump will just keep on pumping brake fluid out until you close it. Then do the other side. Simple as that. No need to do the traditional pump pump open close fiasco like with other cars.
  3. Apr 20, 2020 at 10:39 AM
    rainyben45
    Ben
    Ventura County
