Extended Brake Lines
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dumneezooo, Jun 30, 2022.
  1. Jun 30, 2022 at 12:25 PM
    Dumneezooo
    Dumneezooo [OP] Well-Known Member
    2014 DCLB MGM TRD Sport
    Hey fellas I'm totally confused on whether extended brake lines are needed or not
    Planning on getting a 5100s, 885, JBA UCA, and medium Dakars lift. Do I need to extend my brake lines? Only rear or both front and rear?
    Will be taking my truck offroad.
    Thank you I'm advance
  2. Jun 30, 2022 at 12:43 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I have a 4” lift
    You can get by without replacing them, fronts may be a little Tight when suspension is all extended
    Dumneezooo[OP] likes this.
  3. Jun 30, 2022 at 12:44 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    My guess is you'll want it for the rear, but not the front. From my readings, the fronts should be more than long enough for extended length travel. I ran 885's on the front without extended lines, off-road and was fine. When I switched to my Icon RXT leaf pack, it was recommended to run extended lines. So I did and installed the Crown lines offered through Headstrong Offroad.
  4. Jun 30, 2022 at 1:15 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    On my 2nd Gen lift (Icon stage 8 extended travel) I went with 1" extended fronts/4" back Crown lines from Headstrong Offroad. When i checked the front at full droop / full wheel lock the oem lines were stretched to the max. 1" extended gave it some slack... anything over that could be too long and possibly get caught up in the coils.
  5. Jun 30, 2022 at 1:18 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I went with +2 in the rear (~3” lift)
  6. Jun 30, 2022 at 1:33 PM
    Dumneezooo
    Where did you get 2"? All I've found are over 4"
  7. Jun 30, 2022 at 2:39 PM
    rnish
    Tacoma 2nd gen
    I don’t remember exactly. Its been a few years. I hang out at the usual places. Wheelers, HeadStrong. :notsure:
  8. Jun 30, 2022 at 4:10 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    J
    Just go to Crowns website they’ll make to spec if you want.
