Extended Brake lines
Discussion in 'Technical Chat' started by solus, Jun 2, 2010.
  1. Jun 2, 2010 at 10:39 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
  2. Jun 2, 2010 at 10:45 AM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    Boulder Creek, CA (Nor-Cal)
    2010 SSM DCLB
    AP, and wheelers sells some.
  3. Jun 2, 2010 at 10:50 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^after all the BS with AP I think I'll skip them
  4. Jun 2, 2010 at 11:35 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    bump
  5. Jun 2, 2010 at 11:52 AM
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    That's too bad since we have them in stock and can ship them for $6 via Priority Mail! :D
  6. Jun 2, 2010 at 11:54 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    lol... let me take a look
  7. Jun 2, 2010 at 1:07 PM
    allpro
    Montana
    Attached is a pic of our extended lines on my truck with our new leafs that are close to 5" of lift:
  8. Jun 2, 2010 at 1:22 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^thanks
  9. Jun 2, 2010 at 1:39 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    thats odd, I emailed your guys a few weeks ago when I ordered my ubolt flip about to see if your lines would work with my 6" alcans, and they said probably not.
    Will they work? if so, I will order up a set:)
    Justin
  10. Jun 2, 2010 at 1:50 PM
    allpro
    Montana
    As pictured above is with approx 5" of lift, so they will likely work with 6" of lift, but depends on how much flex you're getting as well. We just put those springs on my truck a few weeks ago, so we hadn't tried them with a lift larger than 3" prior to that.
  11. Jun 2, 2010 at 1:52 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I have AP ones and they haven't failed me yet! ;)
    OP - Just keep in mind that it may be a real PIA to get the OE ones off. My ride was built in MX and they torqued them so tight that the flare flared out so much that I essensially cur a new thread on the way out - I was the hardest part of changing out my rear third but at least I am not stretching my lines when I flex. Good luck!
  12. Jun 2, 2010 at 2:03 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    mines built in Cali (little mexico)
  13. Jun 2, 2010 at 2:09 PM
    HBMurphy
    Paul
    So California Coast
    None
    Or is that Nor Mex ;)
  14. Jun 2, 2010 at 2:34 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    just so everyone who is viewing this thread the lines that toytec sells are 23" while AP states that theres are 24"
  15. Jun 6, 2010 at 5:00 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    I used ToyTec, but my setup was custom. I didn't use the rear lift block or shocks that came with the kit. You really don't NEED longer lines if you're doing the RCD kit. It comes with a brake line relocation bracket.
  16. May 25, 2017 at 12:46 PM
    Cdsk8er8
    Cdsk8er8 New Member
    I have a 2010 tacoma with a 4 inch lift. Who ever did the lift didn't extend the brake lines or wheel sensors in the front. As a result I now have no wheel censor and abs and track lights are on because they got rubbed apart while playing. And my brake lines are in need of upgrade. I tried reconnecting the wires for wheel censor but the lights are still on. Is there a kit to fix the censor? What is my nest bet for steel extended brake lines? I've had trouble pinpointing just the front extended lines for a 2010.
  17. May 25, 2017 at 6:24 PM
    buyobuyo
    buyobuyo Well-Known Member
    Jeremy
    Colonial Beach, VA
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
  18. Sep 12, 2017 at 5:58 AM
    Twitch896
    Twitch896 Member
    06 dclb
    What size would I need for the old man emu Dakar 2.75" rear
