Extended cab Pop & lock wiring question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whiting1977, Oct 29, 2014.
  1. Oct 29, 2014 at 11:20 AM
    whiting1977
    whiting1977 [OP] Well-Known Member
    Sacramento CA
    2014 SR5 PreRunner
    So I have searched and searched for an answer but I only seem to find posts referring to a Double Cab whereas I have an Extended Cab. A friend installed my PL8521 Pop & Lock power tailgate lock and I have a question. He followed the instructions using the Blue w/Red(pink) and Blue w/Black wires and the lock works just fine except that it unlocks on the first pulse (driver side door) of my Extended Cab. Is there wiring that would only unlock the PL8521 on the second pulse (passenger side door) so the actuator will not switch unnecessarily and possibly wear out prematurely?
  2. Oct 29, 2014 at 9:59 PM
    TacomaTruckParts
    TacomaTruckParts Well-Known Member
    Jesse
    San Gabriel
    Yes.... wire it up to the passenger side and it will unlock with two clicks of the remote.
    check out my write-up here. you can see the wires I tapped into.
    Jesse
