Extended coilover on LT setup for short while
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IvanhoeTaco, Nov 28, 2021.
  1. Nov 28, 2021 at 1:52 PM
    IvanhoeTaco
    IvanhoeTaco [OP] Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Wanting to go +2 LT.
    Whats the worst that would happen if I ran an extended coilover on a LT setup for a short while until I could flip current coilovers and get whats needed? The coilover would be my limiting factor?
    I see camburg sells a +2 kit that you can use your current coilovers on until you can upgrade.
    Id rather go total chaos route. But they obviously intend on a LT coilover being used.
    Could I run a fox 2.5 extended travel with a total chaos LT setup?
  2. Nov 28, 2021 at 1:58 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Yeah it'll work. Just won't have as much wheel travel as with the LT set.
    Edit: I have a +2 kit with extended travel ADS and I wheel them pretty hard. So far no problems. Just can't get the height you might be wanting out if the mid travel coilovers
    IvanhoeTaco[OP] likes this.
  3. Nov 28, 2021 at 2:06 PM
    IvanhoeTaco
    Eastern NC
    Nice! Thank you for the actuall experience input!
