Extended length abs wire?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff1795, Aug 13, 2017.
  1. Aug 14, 2017 at 3:22 PM
    erok81
    erok81 Well-Known Member
    Imposter
    I haven't jumped it but fully drooped/turned either direction I have inches of play in it. Limit straps are limit straps. Regardless what I'm doing. I have maybe 300-350 off road miles on the front LT kit. Many full droop and full comp cycles too.
    If I allow my suspension to fully droop without a limit strap and let the uniballs bind (the cv won't even turn) it starts to get mildly tight. But nowhere near ripping out.
    You can see full droop there is plenty of slack in the wire.
  2. Aug 14, 2017 at 3:32 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The bigger spring is stretching it while turning?
  3. Aug 14, 2017 at 4:38 PM
    Jeff1795
    Jeff1795 [OP] Well-Known Member
    Panama City FL
    LT 2017 TRD Sport 4x4 Access Cab 6-Speed
    @erok81 as soon as I get my new wire I'm going to route it like yours and and adjust the limiting straps. And hopefully it will not leave me in the middle of the trail stuck in 2wd! I wonder how different the total chaos kit is from yours.
    90yota and hiPSI like this.
  4. Sep 15, 2017 at 1:51 PM
    TrapComa
    TrapComa Well-Known Member
    Mason
    Cedar Park, TX
    07 Indigo Ink LT PreRunner
    Wannabe prerunner, wannabe overlander
    I have Total Chaos +3.5 and Maxtrac spindles. It gets pretty tight at absolute full droop, but with the limit straps set it's not too tight
  5. Sep 15, 2017 at 3:58 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    That's be the truck won't go into 4wd with a faulty sensor or wire.
  6. Jun 30, 2018 at 8:23 AM
    zakattak
    zakattak Well-Known Member
    Zak
    California, MD
    2015 TRD Sport DCLB
    What replacement wire are you guys buying? Can we not just buy a longer wire and replace the old with that?!
  7. Nov 12, 2018 at 8:14 PM
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    In the cable world lingo, this cable is not shielded. There is no metallic shield preventing EMI ingress. If there was I would expect to see at least one of the ends have a metal connector or a drain wire connected to the shield which is then attached to the metal connector or the frame. This allows the captured EMI to be shunted to ground. This is possibly an impedance controlled twisted pair. But I can't determine that unless someone can get me a part number. Based on how I think an abs sensor works, the resistance of the cable is probably important. Which means the length of the cable is also important. There is likely a lower resistance per foot cable out there. But I need a part number (and not the Toyota part number).
  8. Nov 12, 2018 at 8:42 PM
    zakattak
    Zak
    California, MD
    2015 TRD Sport DCLB
    I supose I should update my issue huh
    So I tore open my abs cable, cut it, soldered it back together with an extended chunk I got for free at the pick and pull (just cut it out) and boom... Problem solved! No more abs bs. No buying a cable, no sensor rewiring. Just cut your dam cables and splice in a new one. Now then... I am a recertifier solder tech in the navy... So I did a quality solder job, Flux, isypropal alcohol cleaning, 4 stages of heat shrink and environmental shielding over it all once done. BUT this did solve my issues. And can most likely solve yours. My.02 is to teach yourselves how to solder. The right way. Makes electrical issues much easier to fix... The right way.
  9. Nov 13, 2018 at 1:20 PM
    08BajaBoy
    Brian
    Southern Cal
    @zakattak thank you for your service. I can appreciate your recent comment. I am a product manager at a cable manufacturer on the west coast that supports many military applications. That was my guess. If the cable was that sensitive they would done more to protect it.
  10. Feb 3, 2019 at 1:41 PM
    1nonlygarcia
    1nonlygarcia Well-Known Member
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    Pending prerunner long travel
    Okay I tore mine installing my LT kit with maxtrac spindles. How did you do it or you willing to do another one?
  11. Feb 3, 2019 at 2:18 PM
    08BajaBoy
    Brian
    Southern Cal
    @1nonlygarcia are you cable of soldering? Or understand crimping wire? You probably tore it well before full droop. I am on stock length ucas/shocks and I am close to a tight wire at full droop. What length LT do you have?
  12. Feb 3, 2019 at 4:34 PM
    1nonlygarcia
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    I tore it because I dropped my spindle on the installation. :facepalm:I have the 3.5 race series from TC. As soon As I seen it I just took the driver side off as well.
  13. Feb 3, 2019 at 5:05 PM
    08BajaBoy
    Brian
    Southern Cal
    Yep, order of operations is important...sorry didn't mean rub salt in the wound. Haha
    You probably need an additional 6 inches. Head to the pick a part and cut a set off if a truck. That way you don't have to worry about the sensor termination, only the splice. A mechanical crimp splice is not ideal but doesn't require specialty tools.
