Extended Length Brake Lines
Discussion in 'Suspension' started by cstephan, Feb 6, 2013.
  1. Feb 6, 2013 at 8:00 AM
    cstephan
    cstephan [OP] Jack Of All - Master at none
    Hendersonville, Nc
    17 Taco TRDOR -DCSB- Gov. Controled Special
    Hold my BEER and WATCH THIS
    Hey guys, i just got my complete lift in from IronMan 4x4 2.5" lift. I wanted to know, would you guys also recommend buying some extended length brake lines?
  2. Feb 6, 2013 at 11:25 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If you are going to be flexing out the rear suspension a bunch, it is an extra safeguard to get longer rear lines.
  3. Feb 6, 2013 at 11:31 AM
    bzzr2
    bzzr2 Well-Known Member
    it is really not required, my current rear shocks are 24.75inches extended, so a bit longer than what comes with OME or IronMan (I believe they use the same length rear shock) and there is no need for longer lines. I'm going to go an inch longer this spring and there is still no need, but what I will do is space the mount for the brake lines up 1/2 - 3/4 of an inch to be sure i still have a safe amount of slack. there is a thread somewhere about this but not sure where, very simple and cheaper and result is same.
