Extended rear shackles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ApexTaco, Mar 15, 2022.
  1. Mar 15, 2022 at 10:53 AM
    ApexTaco
    ApexTaco [OP] Well-Known Member
    Tacoma TRD 2018
    6” lift, full body armor( Hline bumpers, Hooke road roof rack W recovery board mounts, icon leaf springs, spidertrax spacers1.25”, 35x12.50xr20” tires, fuel 20x10” rims, total Chaos bed stiffeners, blacked out tail lights, full light kit pod lights, front and rear light bars, skid plate, rough country steps.
    Looking for 2” extended rear leaf spring shackles. Can’t find any for 3rd gen only 2nd. Has anyone else had this issue or come across needing extended rear shackles?
  2. Mar 15, 2022 at 11:15 AM
    eurowner
    eurowner Duke Sky
    Scoty
  3. Mar 15, 2022 at 5:33 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Are you lowering your truck? Not sure why else you would use a longer shackle with the Tacoma design. I am genuinely curious about this...
    kgilly and Mark77 like this.
  4. Mar 15, 2022 at 6:50 PM
    maileboy
    maileboy Well-Known Member
    David
    Mt. View (Big Island) but from Maili
    2017 TRD OFF-ROAD 4dr 3.5-auto, Magnetic Grey
    Pretty sure it would lift the truck…..cheap lift? Like in the 50’s…"
  5. Mar 15, 2022 at 6:57 PM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    You might want to glance under your truck to check out how the spring hangers are arranged, longer shackles would lower a 3rd gen.
  6. Mar 15, 2022 at 6:57 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Nada. In the stock shackle setup, a longer shackle will lower the rear. With a shackle flip, a longer shackle would lift.
    Bee Finn, skeletron and Key-Rei like this.
  7. Mar 16, 2022 at 3:16 AM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Lo-Ri-Der… Rubin’ my Tyres!
    ScootARoot and Jojee117 like this.
  8. Mar 16, 2022 at 8:04 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  9. Mar 16, 2022 at 8:19 AM
    Kefka
    Kefka Well-Known Member
    01001010 01101111 01101000 01101110
    2019 MBM TRD PRO
    Random but can you run Archive Garage shackles without hammer hangers? If so, is there any benefit?
  10. Mar 17, 2022 at 9:13 AM
    ApexTaco
    Tacoma TRD 2018
    So I had my truck lifted on a 6” that wasn’t high enough so I went to 35” tires gave me more ground clearance but the rims looked super small. So I changed the rim to a 20” on 35’s then I couldn’t turn so I added a 1” body lift. Still couldn’t turn full lock so the shop recommended a 2” leveling kit now I can turn full lock added some JBA UCA to help with angles now the truck looks like it’s from south fucking Carolina it’s 1.5 lower in the rear I’m trying to add 2” lift to the back without spending a ton of money I’m already thousands over budget on this truck.
    ScootARoot likes this.
  11. Mar 17, 2022 at 9:14 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Post a picture of the truck.
    ohcaltexscar and ScootARoot like this.
  12. Mar 17, 2022 at 9:21 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    The guy with an 8" lift, 20's and 35's shouldn't be making fun of anyone. You and the Carolina Squat boys are kindred spirits
    roboturner, gsubioguy and gman2431 like this.
  13. Mar 17, 2022 at 9:35 AM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Yeah they should work fine I could imagine, benefit would be better bushings.
  14. Mar 17, 2022 at 9:38 AM
    ApexTaco
    Tacoma TRD 2018
    9” of lift and no I don’t like the squat look or anything close to that.
  15. Mar 17, 2022 at 9:39 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you can't turn on 35s, stop lifting your truck higher. Start cutting shit out of the way. Cab mount chop/relocate will be your friend here. Also, leveling kit on top of a 6" lift? Say what now?
  16. Mar 17, 2022 at 9:41 AM
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
  17. Mar 17, 2022 at 9:44 AM
    ApexTaco
    Tacoma TRD 2018
    yes they stacked the lifts and added a 1” body lift so it sits 9” in front and 7.5 in rear so I’m looking for a way to lift the rear 2” up
  18. Mar 17, 2022 at 9:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Well, the first step is to remove that additional spacer that they added on, that's just not safe. Remove that and you'll be sitting level/a little rake. Then start cutting stuff to make the tires fit.
    skeletron likes this.
  19. Mar 17, 2022 at 9:46 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    You would have to do a reverse shackle conversion. The Tacoma shackles are opposite of full size trucks.
  20. Mar 17, 2022 at 9:46 AM
    fourfourone
