Extended Service Schedule
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PaulK, Jan 19, 2024.
  1. Jan 19, 2024 at 11:41 AM
    PaulK
    PaulK [OP] Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    My 2013 Tacoma is creeping up on 105k miles, which is where the factory provided regular maintenance schedule booklet ends. Does anyone know where I could download either an extended schedule, or a blank factory maintenance and warrantee book that I could use for this
    I know it's just flip back to 5k and repeat, but mine's already written on and I like clean records. I plan to go at least another 100k.
    Thanks
  2. Jan 19, 2024 at 11:52 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I BELIEVE you can download the owners manual for your truck on toyotas website.
  3. Jan 19, 2024 at 1:12 PM
    TacoTuesday1
    FL
    you just do the same thing and repeat. And add in parts that wear according to their life expectancy. And perform visual inspections to check.
    Or wait for symptoms to arise indicating a worn part.
    if something is to be done every 5k or every 6-12mo it doesn’t really matter total miles.
    Mfgs do not create schedules beyond 100k as they generally deem that time for a car to fall apart or be traded in for a more expensive worse new model.
  4. Jan 19, 2024 at 5:34 PM
    PaulK
    Paul
    Pittsburgh, PA
    Yup...I know all of that. I'm just after an easy and organized way to document it for the next 100k.
  5. Jan 19, 2024 at 5:40 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  6. Jan 19, 2024 at 5:42 PM
    Bishop84
    Bishop84 Well-Known Member
    Coolant shortens to nearly half intervals after the first, the rest cycle normally.
    Dm93 likes this.
  7. Jan 19, 2024 at 5:47 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Something like this, if you ever want to sell it all you gotta do is print it out and you have everything right there.
  8. Jan 19, 2024 at 7:04 PM
    Bishop84
    Rugged Trails :bananadead:
  9. Jan 19, 2024 at 7:06 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Idk I have no complaints about them, gona have to find something different next time though since they are discontinued.
  10. Jan 19, 2024 at 7:08 PM
    Bishop84
    They were standard on Nissan offroad trucks and they had loads of complaints, often called "rugged fails" But still better than the stupid Dunflops that came standard on most 2nd gen tacomas.
    What is your spare tire?
    Dm93[QUOTED] likes this.
  11. Jan 19, 2024 at 7:16 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    For the amount of gravel roads I drive on and thorns I drive through they have held up quite well, the original set had one that developed a bad spot at around 44k but this set has been fine so far.
    Spare is original Rugged Trail.
    I'm not sure what to go with next time, I thought about BFG all terrains but alot of people say they are noisy and my friend had them on his F-150 and the sidewalls started cracking severely.
  12. Jan 19, 2024 at 7:35 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    My rugged fails were NOT good in the snow and made 47k miles.
    I then went to Hankook Dyna Pro AT/M, much better in the snow. and went 79k miles.
    I'm now on DynaPro AT2. (Took the place of the AT/M)
    I even dug a 9mm case out of mine. :eek:
    She went 3 more years after that.
  13. Jan 19, 2024 at 7:42 PM
    Bishop84
    BFG still makes a tame all terrain. https://www.bfgoodrichtires.com/auto/tires/trail-terrain-t-a
    It's an odd duck because of the continuous outer edge, but they are doing fairly good so far. We sell them as all weathers but they arent amazing in the cold.
    I'm running a Canadian re-branded cooper for summer, https://coopertire.com/en-us/find-tires/all-tires/discoverer-atp-ii taking a shit kicking from me so far and crazy even wear.
    I won't buy hankooks because I had a set of ipikes that pissed me off years ago. I'm easily fouled.
  14. Jan 19, 2024 at 9:18 PM
    PaulK
    Paul
    Pittsburgh, PA
    TnShooter and Dm93 like this.
  15. Jan 19, 2024 at 9:22 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    TnShooter likes this.
  16. Jan 19, 2024 at 9:40 PM
    TnShooter
    Deogee
    STOCK
    That will work just great:thumbsup:
    You’re doing better than I am.
    Other than oil changes. I do the rest “close to”, “when I feel like”, or “when it’s convenient”.
    It’s good that you don’t do what I do.
