Extended Thread Lug Question
Discussion in 'Wheels & Tires' started by Buckaroo1993, Aug 8, 2018.
  1. Aug 8, 2018 at 4:44 PM
    Buckaroo1993
    Buckaroo1993 [OP] Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    I made a boo boo. I accidentally bought extended thread lugs for my new HELO 878 wheels. All else being equal and the ONLY difference is the extended shank, will these still work on my 2003 DC 4WD with the new wheels?
  2. Aug 8, 2018 at 4:52 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Only way to find out is to try one on and see if the extended shoulder bottoms out on the hub before you're able to torque the wheels properly. Worst, case scenario, it bottoms out (DO NOT DRIVE LIKE THIS) and the wheel won't be torqued down. You could sell them here- I'm sure you'll get a buyer right away. The could be some wobble and/or possible strain enough to break a stud due to movement. Best case scenario, you're able to torque normally and you're G2G.
    Either way for less than $50 you'd probably be better off getting the right lugs for something as important as your wheels.
    Rat_Bastard likes this.
  3. Aug 8, 2018 at 5:04 PM
    Buckaroo1993
    Vinny
    Georgia
    The shoulder of the extended shank leaves about 1/8" gap before going past the back face of the wheel.
  4. Aug 8, 2018 at 5:10 PM
    Buckaroo1993
    Vinny
    Georgia
    I may have made a boo boo. I accidentally bought extended thread lugs for my new HELO 878 wheels. All else being equal and the ONLY difference is the extended shank, will these still work on my 2003 DC 4WD with the new wheels? I put the lug in the hole and there is an 1/8" gap between the end of the extended shank and the back face of the wheel. Good? Or no?
  5. Aug 10, 2018 at 3:31 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    So if I'm reading this right, the extended lug will seat correctly into the wheel, goes into it and stops 1/8" before the back of the wheel? If that's the case you're good :thumbsup:
    If your extended lugs went all the way through and poked out of the back of the lug opening then you'd have a problem.
    SCSPerformance likes this.
  6. Aug 10, 2018 at 5:26 PM
    Buckaroo1993
    Vinny
    Georgia
    Correct on the first part.
