Extended travel CV or Reboot my Toyota OEM's?
Discussion in '1st Gen. Tacomas (1995-2004)' started by skycamper, Apr 22, 2024.
  1. Apr 23, 2024 at 6:29 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    cruxofthebisquit and Kwikvette like this.
  2. Apr 23, 2024 at 6:34 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Remove the diff drop, do the bootslide mod with new OEM boots and you'll be fine.
    skycamper[QUOTED][OP] likes this.
  3. Apr 23, 2024 at 6:43 PM
    Nano909
    Xcab 3.4 4wd 5MT
  4. Apr 23, 2024 at 8:48 PM
    skycamper
    skycamper [OP] Well-Known Member
    Abraham
    2001 Tacoma 4x4 2.7L Ext Cab
    3" Lift w/ 5100's and EMU 882 springs , General Leaf Spring and AAL in rear with 5100. Diff drop, carrier drop, 3 degee axle shims. Trail Gear Tube Bumper. Tundra brake mod.
    I’ve watched that video several times! Thanks guys!! I think I’ll get an O'Reilly unit , and use the reboot kit I’ve been storing in my garage during Covid, and do this boot slide mod. Folks don’t seem to be against that! I could think about lowering it but I really like the way it sits now. Since I don’t wheel I’ll just take things nice and easy. This truck usually just hauls stuff or pulls a utility trailer.
  5. Apr 23, 2024 at 8:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You will tear boots on the O'Reilly unit
    The boot slide mod only works for OEM-style CV axles
    Just lower it, not sure why you're so against it considering how IFS works
    Superdave1.0 likes this.
  6. Apr 23, 2024 at 8:56 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    The store brands can sometimes have less articulation than stock. I installed some aftermarket ones on an FJ cruiser recently, at full droop I couldn't even turn the wheel. CV was binding.
  7. Apr 23, 2024 at 9:18 PM
    Nano909
    Xcab 3.4 4wd 5MT
    I think he meant he was going to buy an Oreilly axle so he can take his time rebooting his stock OEM axles with OEM boots (I hope).
    It's double the work but if you need the truck then I get it.
    skycamper[OP] likes this.
  8. Apr 23, 2024 at 9:45 PM
    skycamper
    Abraham
    Yes this is correct, I don’t have a choice, I knew this would be a problem during Covid when I lifted the truck so I ended up buying the tools and the boot kit and luckily when this one tore, I knew exactly the day that it did and I stopped driving it. Luckily, it’s not rained and The CV axle hasn’t made any noise so I know it can be rebooted! Unfortunately, I’ve not done this before and I’m only moderately handy, but I’m getting better, So I’ll have to watch the rebooting videos about 30 more times before I get started.
  9. Apr 23, 2024 at 10:08 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Napa axles definitely had less articulation when I used them, I could hear them binding under fill droop and higher speed. Went back to oem, issue never became present again.
    I’ve seen diff drops actually bend the bolts at the front mounts due to the angle being thrown off by the spacers, maybe not an issue if you don’t wheel your rig, but it does throw off the geometry.
    OP, if you have a winch and a tube front bumper it’ll definitely help mellow out your lift up front, the springs will settle over time
    skycamper[OP] and Superdave1.0 like this.
  10. Apr 24, 2024 at 5:53 AM
    skycamper
    Abraham
    I thought the spacers were meant to help correct the diff angle when you lift the truck?
