Extended travel, high articulation CV from O’Reillys?
Discussion in '1st Gen. Tacomas (1995-2004)' started by StevenP, Jul 3, 2020.
  1. Aug 14, 2024 at 12:51 PM
    #181
    enilson
    enilson Active Member
    Seattle
    2008 Reg Cab 4x4 2.7l
    Just had a boot blowout and looking to add these to my rig (actually a 4th gen 4runner but this thread seems the most comprehensive). I see RockAuto has these for less than 1/2 the price of NAPA and Oreillys. I assume I'll eventually blow the boots on these as well (~2.75" lift) and so the lifetime warranty will come in handy. My question is, has anyone dealt with getting these replaced from Rockauto?
    I found this document on their website which makes me question them replacing them if they fail. They state that "damaged boots" and "broken shafts" aren't covered by their lifetime warranty... o_O
    https://www.rockauto.com/en/moreinfo.php?pk=15778889&cc=0&pt=2288&jsn=3
    https://www.rockauto.com/genImages/570/Automotive-CV-Axle-Warranty.pdf
  2. Aug 14, 2024 at 12:53 PM
    #182
    Wulf
    Wulf no brain just damage
    rock raisin
    I would skip buying them from Rock Auto if you plan on using any kind of warranty from them, they're a hassle and any savings may be eaten by shipping costs. if you expect to warranty Id buy from a parts chain so you can walk in and exchange with less fuss
  3. Aug 14, 2024 at 1:00 PM
    #183
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    THIS^^^
    Would be wasteful in time and energy to get these assuming regular warranty replacement by shipping. However the savings is worth it if you're willing to reboot them yourself
    enilson, MadNachos and Wulf[QUOTED] like this.
  4. Aug 14, 2024 at 1:46 PM
    #184
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Yup. I was 3 states away with a broken axle and walked into an Oreilly and got the axle warrantied and walked right out in under 5 minutes. Can't do that with RockAuto.
    Black97v6MT and enilson like this.
  5. Aug 14, 2024 at 1:47 PM
    #185
    Nano909
    Xcab 3.4 4wd 5MT
    Don't waste your time. Reboot your current axles and do the bootslide mod.
    Bandido and MadNachos like this.
  6. Aug 14, 2024 at 6:37 PM
    #186
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    I agree unless the CVs are completely toast.
    Ages ago I got some rebuilt rear CVs for a BMW e30 and made the mistake of giving them my originals as a core. I broke 3 CV joints within two months with the rebuilds. Cardone. Eventually I gave up, sourced some decent CV shafts and rebuilt them myself, they were perfect. Put 80K on them before I sold the car. Always rebuild them if they are in good shape.
  7. Aug 23, 2024 at 4:00 PM
    #187
    enilson
    Seattle
    Thanks all for the advice and great call with shipping costs. In terms of ease of warranty, do you all prefer Napa or Oreillys?
    How would I be wasting my time? Not being snarky, just curious why. Seems like the extended travel would be great for my lift amount with extended travel struts (Dobinsons). Not familiar with the boot mod.
  8. Aug 23, 2024 at 4:24 PM
    #188
    Nano909
    Xcab 3.4 4wd 5MT
    The axles are pretty weak. If you don't offroad and just want something easy to warranty, then they're good for that. Otherwise OEM axles are far superior. Doing the bootslide mod will ensure you'll never rip another boot again.
    https://youtu.be/vcCT4UgFUTw?si=IZhTEAdrKUmO5t2I
    enilson[QUOTED] and Black97v6MT like this.
  9. Aug 23, 2024 at 6:03 PM
    #189
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    What coils are you running with the Dobinson’s?
  10. Aug 23, 2024 at 6:07 PM
    #190
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    F RA
    enilson likes this.
  11. Aug 23, 2024 at 6:51 PM
    #191
    enilson
    Seattle
    Cool, thanks for the video. I'll definitely look into that. I do a fair amount of mild off-roading, and just loads of exploring the mountains where I live. Have you been seeing these axle fail?
    Nano909[QUOTED] likes this.
  12. Aug 23, 2024 at 6:52 PM
    #192
    enilson
    Seattle
    Again, I'm in a 4th gen 4runner, just here because it's one of the most active threads on these axles. But my setup is c59-350 coils with gs59-220 struts.
    Black97v6MT likes this.
  13. Aug 23, 2024 at 7:20 PM
    #193
    Nano909
    Xcab 3.4 4wd 5MT
    I've personally broken 5 of them. I don't baby my truck but I've also never broken an OEM axle either.
    enilson[QUOTED] likes this.
  14. Aug 23, 2024 at 8:24 PM
    #194
    enilson
    Seattle
    Dang!
  15. Aug 24, 2024 at 4:29 PM
    #195
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    What were you doing when you broke them? Which brand did you get? There a pretty beefy axle.
  16. Aug 25, 2024 at 8:37 AM
    #196
    Nano909
    Xcab 3.4 4wd 5MT
    Rock crawling. Oreilly extended travel axles. They're not beefy at all.
  17. Aug 26, 2024 at 9:04 AM
    #197
    cynicalrider
    cynicalrider #NFG
    Jersey
    Where are they breaking at? Slip joint? Shaft? Tulip?
  18. Aug 26, 2024 at 9:25 AM
    #198
    Nano909
    Xcab 3.4 4wd 5MT
    3 inner shaft near/at the splines, 2 outer cv.
  19. Aug 26, 2024 at 11:30 AM
    #199
    cynicalrider
    cynicalrider #NFG
    Jersey
    Tire size, lockers, crawl box?
  20. Aug 26, 2024 at 1:10 PM
    #200
    mike759
    mike759 Well-Known Member
    Colorado
    2002 Xtra cab TRD off-road
    2.5" lift, JBA UCA, OME rear leafs, 33s...
    Did they give you a hassle with receipts and such? I bought mine through a shop that installed them, but warrantied and replaced one myself when a boot tore. I brought the receipt from the shop's o'reilly order, which they were reluctant to look at, then told me the lifetime warranty was one time use. Is that true or was it just a dickhead employee?
