Extended travel, high articulation CV from O’Reillys?
Discussion in '1st Gen. Tacomas (1995-2004)' started by StevenP, Jul 3, 2020.
  1. Aug 26, 2024 at 1:39 PM
    #201
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    No. They didn't even look in the box. That employee was being a jerk. I've warrantied their axles 5 times already with literally no issues.
  2. Aug 26, 2024 at 1:40 PM
    #202
    Nano909
    Xcab 3.4 4wd 5MT
    33's, yes, no.
  3. Aug 26, 2024 at 1:41 PM
    #203
    cynicalrider
    cynicalrider #NFG
    Jersey
    Damn, breaking on 33's and no crawl box, think I'll skip these. I've only broken one OEM bound up on 35's with the front locked.
    Wulf likes this.
  4. Aug 26, 2024 at 1:42 PM
    #204
    Nano909
    Xcab 3.4 4wd 5MT
    These are good axles if you just want a spare. But they're definitely inferior to OEM.
  5. Aug 26, 2024 at 4:14 PM
    #205
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    I have maybe had mine a year. Torn boot. Oems appear to be on back order
  6. Mar 9, 2025 at 8:51 PM
    #206
    N8 95 Tacoma
    N8 95 Tacoma Active Member
    95 3.4L v6
    Marlin crawler transmission, warn manual hub lockers, icon 2.5 suspension, alcan off road leaf springs, ARB front and rear air locker with compressor switch and front and rear switch.
    Hey there, I found this thread and hopefully can get an explanation as to why this extended travel CV axle won't fit manual hubs. As far as I can see and understand (I'm still learning so I'm seeking an answer, not a roast session) the only difference is the hub is always engaged with automatic locking hub, then with manual, it is disengaged from the CV until you turn the dial to 4×4; which in that state is the same as auto locking hub right???? Sadly I can't find any extended travel CV axles for manual hubs. I too really admire this advantage in more articulation since I got a pretty lifted front end.
  7. Mar 9, 2025 at 8:58 PM
    #207
    Wulf
    Wulf no brain just damage
    rock raisin
    the ADD and manual hub CVs have a different spline count at the wheel hub end, which is why they aren’t interchangeable.
    N8 95 Tacoma[QUOTED] likes this.
  8. Mar 9, 2025 at 9:12 PM
    #208
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Like @Wulf said the outer splines are different.
    I've come to the same conclusion as other guys above and I'll just continue using the "boot slide" mod on OEM CV axles. All other axles will likely be inferior unless you're talking RCV or something... and then you'll just break your front differential which is more expensive of a repair.
    N8 95 Tacoma[QUOTED] and Wulf like this.
  9. Mar 19, 2025 at 5:05 PM
    #209
    N8 95 Tacoma
    95 3.4L v6
    Thanks for the info!
  10. Apr 1, 2025 at 1:18 AM
    #210
    jasonrobo
    jasonrobo New Member
    Baton Rouge, Louisiana
    Tacoma TRD Off-road DC V6
    Any one have the link to the other conversation?
    TIA!
  11. Apr 1, 2025 at 9:15 AM
    #211
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    These axles have been pretty good to me so far. I've been running mine for 2 years now and no issues. I like the they don't bind at full droop. I'm running a front locker and almost 35's . I also try not to let the front get bound up or shock loaded. Maybe I'm just lucky. But my experience has been positive.
    15psd likes this.
