Extended travel, high articulation CV from O’Reillys?
Discussion in '1st Gen. Tacomas (1995-2004)' started by StevenP, Jul 3, 2020.
  1. May 18, 2021 at 10:32 AM
    #121
    eon_blue
    Azusa, CA
    If it's not coming out with some force on the pry bar, turn the axle a bit and try again. You want that c-clip in just the right place for it to pop out easily.
  2. May 18, 2021 at 12:12 PM
    #122
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just cut them off, go 40s n tons
  3. May 18, 2021 at 1:18 PM
    #123
    Bluecord
    Bluecord Well-Known Member
    Jeff
    Louisiana
    2003 Tacoma 4x4 TRD Lunar Mist Metallic
    Unfortunately not in my future. At least not my immediate future...
  4. May 18, 2021 at 1:36 PM
    #124
    Kwikvette
    Fresno County
    4 run, 2 don't
    Simple bolt-on kit :burp:
  5. Dec 8, 2021 at 6:47 PM
    #125
    Austintaco
    Austintaco Well-Known Member
    Patrick
    Austin,TX
    03 DC TRD with some stuff
    King coilovers, Tundra brakes, All pro Expo springs, Timbrens, ARB bumper, All Pro Sliders and Rear bumper, Landcruiser wheels, sold my Flippac, regeared to 4.88’s, ARB front Locker
    I’m reviving this thread since it seems like autozone and Napa both carry these extended travel CVs as well. I have one coming in at NAPA to look at. My current CVs are my originals and I rebooted and rebuilt them a few years ago. They held up, but the extended travel boots did not. Any more reports on these, good or bad?
  6. Dec 8, 2021 at 6:54 PM
    #126
    Kwikvette
    Fresno County
    4 run, 2 don't
    I may have about what...15k to 20k miles on them now since my boots tore and I'm reporting no weird noise or odd driving at all. That's on top of the 5k or more miles I put on them before I noticed the torn boots?
    Granted I haven't gone wheeling since the end of September, but I have gone on 4-5 camping trips since then...each over 3+hrs away each way.
  7. Dec 8, 2021 at 7:15 PM
    #127
    Austintaco
    Patrick
    Austin,TX
    Kwikvette, that’s great to hear. I saw your review on the O’reilly site. I think I’ll go this route and pick up the extended travel CV from NAPA, it has to be the same MFR, same specs and same photo, and I’ll pull and reboot mine for a trail spare.
  8. Dec 14, 2021 at 6:07 PM
    #128
    Austintaco
    Patrick
    Austin,TX
    I ended up with one from O’reilly’s because NAPA either sold the one out from under me that they ordered for me or could not find it. Everything is going smooth except as others have pointed out, getting these in without a lip to put a crow bar on and seat it is proving to be a huge PITA. I can get it to the first stop and then nothing. Just venting. Taking a break.Tried lining it up straight, tapping with a rubber mallet at the end. It’s not budging.
  9. Dec 14, 2021 at 6:20 PM
    #129
    Wulf
    rock raisin
    Did you grease the splines at all?
  10. Dec 14, 2021 at 7:12 PM
    #130
    Kwikvette
    Fresno County
    4 run, 2 don't
    As stated, did you grease them?
    Also, make sure that little C clip from your old CV axle came out otherwise it might be stuck in there.
    Mine seated easily by hand.
    Wulf[QUOTED] likes this.
  11. Dec 14, 2021 at 7:19 PM
    #131
    Austintaco
    Patrick
    Austin,TX
    Yup, grease on the spline, old clip is on the old CV and I have tried clip up, clip down, shake it all around, hokey pokey…LOL. I’m having a beer and then I’m going back out to just keep rotating it and trying again. I never had this much of an issue with other CVs, but they all had a lip to bang on. Thanks for the tips. It will go in eventually.
    Kwikvette likes this.
  12. Dec 14, 2021 at 7:22 PM
    #132
    Kwikvette
    Fresno County
    4 run, 2 don't
    Might just have to do the CV axle delete mod :burp:
    Austintaco likes this.
  13. Dec 14, 2021 at 7:23 PM
    #133
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have never used the lip anyways…hold axle straight and use a mallet on the threaded side. Goes right in.
    Austintaco[QUOTED] likes this.
  14. Dec 14, 2021 at 7:26 PM
    #134
    eon_blue
    Azusa, CA
    Thread the axle nut on the end to protect the threads and then hammer it home. When we did @Kwikvette 's axle seal a couple months ago this same CV axle went in nice and easy that way.
    For me getting them out is the hard part when there's no good place to put a pry bar on
    Austintaco[QUOTED] and Kwikvette like this.
  15. Dec 14, 2021 at 7:29 PM
    #135
    Kwikvette
    Fresno County
    4 run, 2 don't
    Or in my case when we found out we can just yank the CV axle out by hand :rofl:
    Austintaco and eon_blue[QUOTED] like this.
  16. Dec 14, 2021 at 7:38 PM
    #136
    Kwikvette
    Fresno County
    4 run, 2 don't
    I keep mixing this thread up with the other one; the other thread has slightly more specific info about these axles and updates.
  17. Dec 16, 2021 at 7:53 PM
    #137
    Austintaco
    Patrick
    Austin,TX
    I let it sit for a day and did my 24 hour shift. I came back, determined to get it in, and I did. Quite easily, so I will share what I did, in case anyone else has this issue. I almost replaced the C clip with the old one since I read that it was most likely the clip causing the issue, but I decided to try everything again and add in the the “slide pull technique”. I dunked the end in some grease and then rotated the clip with the open end down, but centered and not hanging. I lined up the CV and after a few pushes, it went to the first “stop” as it had been doing previously. I kept the cv straight and basically did a “slide pull” type action and it popped right in! I’ll test drive it tomorrow.
    jasonrobo and eon_blue like this.
  18. Dec 16, 2021 at 8:01 PM
    #138
    Kwikvette
    Fresno County
    4 run, 2 don't
    Glad it went in!
    Though I'm not sure what the difference is that you did? Just need to push it in.
  19. Dec 16, 2021 at 8:22 PM
    #139
    eon_blue
    Azusa, CA
    Sounds like the C clip was the in the perfect spot, the grease he put on there too likely helped
    Kwikvette[QUOTED] likes this.
  20. Dec 16, 2021 at 8:26 PM
    #140
    Kwikvette
    Fresno County
    4 run, 2 don't
