Extended travel rear shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 03f5sp, Feb 21, 2015.
  1. Feb 21, 2015 at 10:29 PM
    03f5sp
    03f5sp [OP] Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Does anyone make a direct a replacement extended travel rear shock for our trucks? When I look for mid travel stuff it always comes up with coilovers. Thanks everyone :)
  2. Feb 22, 2015 at 6:30 AM
    Pigpen
    Dan
    Northwest Montana
    Most aftermarket shocks are extended travel, if you're comparing to stock. Go to any site and look at the specs. Wheeler's Offroad is a good place to look (and buy). Look at compressed length and extended length, then compare to stock. Wheeler's has the old style OME shocks on sale and they ride super plush on and off road.
  3. Feb 22, 2015 at 7:49 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Buy replacements for a TRD Pro / Baja .....gain about an inch more droop travel from the same length shock as stock
  4. Feb 22, 2015 at 7:55 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The problem is collapsed lengths needed for the stock shock placement / mounts doesn't let you get a shock with much more than 10in of travel. The longest rear shock I have found for stock mounts on the frame / axle is the ome n182 rear shock. 10.2in of travel and it won't bottom first before hitting the bumpstop.
  5. Nov 18, 2016 at 9:55 AM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    OME 60066L. Valving is nearly identical to tacoma application specific shock. stem is thicker, you might have to drill out the mount a little? and the bottom busing is different but you can get that as well. collapsed length is almost 16 though so make sure you can accommodate that. should work with dakar and super bumps.
