Extended travel vs. Standard
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma mud, Jul 30, 2011.
  1. Jul 30, 2011 at 9:37 AM
    Tacoma mud
    Tacoma mud [OP] Well-Known Member
    Kyle
    TEXAS
    97' xtra cab sr5 4x4
    soon to come
    I was wondering which ICON C/O (the ext. Travel or the standard travel) would be better for mostly street driving but is still good for some pretty tuff mudding and rocking. Their the same price i just dont know which one would be better for my needs.
    :confused::confused::confused:
  2. Jul 30, 2011 at 10:39 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Prolly standard is my guess. How HC of trails you go on?? hit em every week? or just once twice a year?
  3. Jul 30, 2011 at 10:53 AM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    Yea about once a week nothing much just mud pits nothing really hard core
  4. Jul 30, 2011 at 11:03 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    Pelfrey Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    The extended travel and standard shocks are basically the same, except the "standard" shock has an extra spacer inside to limit shaft travel.
    Do you have stock UCAs? If so, get the standard. From TRDParts4U's page on the extended travel coilovers:
  5. Jul 30, 2011 at 11:06 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    ^Like he said. If you have stock upper control arms you want normal length. If you have aftermarket UCA's (Camburg, Total Chaos, etc) with uniball you get a touch more travel over stock. Aftermarket UCA's you would want the extended travel
  6. Jul 30, 2011 at 11:08 AM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    Yea right now i have the TC ucas, i should get the ext travel then???
  7. Jul 30, 2011 at 11:10 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Absolutley. If you get the standards you will be missing out on the extra travel your UCA's give you. I vote ext travel with resi :) but they are a little pricey!
  8. Jul 30, 2011 at 11:29 AM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    I think if we saw the same ones it about 1000 right??? Plus the 750 TC ucas
  9. Jul 30, 2011 at 11:46 AM
    Cr250jumper
    The moon
    50 shades of tan©
    There are 2 different kinds of each travel (2 standards & 2 extended travel)
    Extended travel without remote reservoir - IVD-5-8615 = about $1100
    Extended travel with remote reservoir - IVD-5-8715 = about $1400
    Standard travel without remote reservoir - IVD-5-8610 = about $1100
    Standard travel with remote reservoir - IVD-5-8710 = about $1400
    http://www.polyperformance.com/shop...4-Runner-2-4WD-0-3-Coil-Over-System-p-90.html
  10. Jul 30, 2011 at 11:48 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    also the extended travel is not so friendly on the cvs. the extendeds are a good mid travel setup for 2wd but can wear on your 4wd
  11. Jul 30, 2011 at 11:49 AM
    Cr250jumper
    The moon
    50 shades of tan©
    ^Very true. Im prerunner so I always forget about cv angles
  12. Jul 30, 2011 at 12:06 PM
    KenLyns
    Belly of the Beast
    Would recommend Extended travel without remote reservoir if you are not doing high-speed runs or jumps. You are never going to overheat the shock fluid with rock crawling or mudding. The exposed reservoir and hose are more vulnerable to damage.
    Extended travel is fine for CVs if you keep the ride height sane. Both standard and extended travel can hurt CVs if the ride height is too high.
  13. Jul 30, 2011 at 12:34 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    But i dont want mess my CVs up!!! So which one should i get i have a 97 4x4
