Extended Warrany
Discussion in '4th Gen. Tacomas (2024+)' started by Tacowrench, Jul 24, 2024.
  1. Apr 3, 2025 at 8:46 PM
    #81
    K_Romer
    K_Romer Well-Known Member
    Ken
    Here is the key law on warranties and how aftermarket work effects them
    The Magnuson-Moss Warranty Act protects consumers from having their vehicle warranty voided solely due to the use of aftermarket parts or modifications, including lift kits, unless the manufacturer can prove the aftermarket item directly caused the failure.
    • What the Act Does:
      The Magnuson-Moss Warranty Act, a federal law, prevents manufacturers from voiding a vehicle's warranty simply because a customer uses aftermarket parts or services, or makes modifications like installing a lift kit.
    • Burden of Proof:
      The burden of proof lies with the manufacturer to demonstrate that the aftermarket part or modification caused or contributed to the failure of the vehicle component in question.
    • Examples:
      • If a vehicle with a lift kit experiences a CV joint failure, the manufacturer would need to prove that the lift kit, and not a manufacturing defect, caused the CV joint to fail such as the increased angle on the joint. This case would likely be reasonable to assume a lift caused a problem with a CV depending on the failure. It could be disputed in court though
      • If a vehicle with a lift kit has a problem with the engine, the manufacturer would need to prove that the lift kit caused the engine problem.
      • If a vehicle with a lift kit has a problem with the power door lock, the manufacturer would need to prove that the lift kit caused the door lock problem.
  2. Apr 4, 2025 at 3:20 AM
    #82
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    What the act doesn't do is pay for your lawyer.
    SOSHeloPilot and OpeCity like this.
  3. Apr 4, 2025 at 7:20 AM
    #83
    Yoda_Mike
    Yoda_Mike YotaWerx Authorized Tuner
    Michael
    South Glens Falls, NY
    2019 Tacoma TRD Sport
    YotaWerx Blackhawk 2.0 tuned. Typer Auto tail light guards. Rough Country tri-fold tonneau cover. Start-X remote starter. Injen CAI. MBPR Armor Plus high clearance exhaust.
    I'm still up in the air on if I'll tune this truck. Not due to warranty concerns (my 2019 was under warranty and tuned most of the 2 years I owned it) but simply because this truck doesn't NEED a tune the way the 3GT did. It runs and drives exceptionally well - far better than a stock 3GT and probably even better than a tuned one. At this point, before adding any weight in mods, I'm completely happy with how the truck drives. That may change in the future when additional weight is added, but that remains to be seen.
  4. Apr 4, 2025 at 7:27 AM
    #84
    K_Romer
    Ken
    If I lift the vehicle and a CV has an issue, I will assume the lift caused the issue and pay for it. If the radio goes out Toyota will fix it. I talked to my local Dealer and the National line and both verified that
    My research did not find any claims issues requiiring a Lawyer. Not saying there havent been any, but I don't see it as a concern where there is clear division between the modifications and any issues. My biggest reason was all the electronics. I had to replace an Amplifier in my Land Cruiser and the part new from Toyota cost more than this warranty. It took me several days of troubleshooting to define the issue as the amplifier. I did find a refurb part for just under $1000. That is on a 2014 Toyota with fewer electronics and integrated systems.
  5. Apr 4, 2025 at 8:55 AM
    #85
    patos tacoma
    patos tacoma Well-Known Member
    I agree, the 4th gen drives and performs better than my 2021 3rd gen that was OTT tuned………BUT , the warranty issue has made me pause on tuning my 4th gen……….really want the extra 30hp and torque….
  6. Apr 4, 2025 at 9:00 AM
    #86
    patos tacoma
    All well and good, BUT while the dealer is looking up “the burden of proof”, the dealer is NOT fixing your truck, and it’s going to cost YOU the repair or an attorney……….
    In the case of a Tune, the repair affected would be engine and/or transmission issues……
    CrispyTacoLover likes this.
  7. Apr 4, 2025 at 9:03 AM
    #87
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
  8. Apr 4, 2025 at 9:37 AM
    #88
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    I learned long ago extended warranties are the biggest scams. Most people today don't own a vehicle passed 3 years anyway. Also dealerships make their money through finance department with insurance, warranties, and add ons. Lastly, we are talking about toyota's here.. one of the most reliable car brands on the planet. Proceed with caution.
  9. Apr 4, 2025 at 11:18 AM
    #89
    K_Romer
    Ken
    On the tune vs an engine issue, you may have a problem getting the warranty to cover it, I agree. If I wanted the extra warranty, I wouldnt get a tune. Anywhere else, I don't see the issue needing a Lawyer.
    I normally avoid these warranties like the plague and told the dealer no thanks. Then through these forums I found out about these discount actual factory plans and looked at what I have done to my Land Cruiser over 10 years, my daughters Land Cruiser over 20 years and my other daughters GX470 over 12 years. Of course looking at the first 10 years since new. For each vehicle there was one repair that cost more than the warranty ($1360) and that is with fewer electronics. Like I said I researched them, called the local dealers and talked to Toyota directly. The GX and 100 series both had a steering rack replaced before 10 years. My 200 needed a new amplifier just before 10 years. I keep vehicles a long time.
    I am 63 and this is the first Vehicle warranty I have purchased, I always have said no up to now. The cost to value seemed pretty good to me in this situation. I did my due dilligaance over several months and feel confident it isnt an issue for me with the local Denver area dealers. Its a Toyota warranty and they look you up, see you have one, and treat it just like it is within the first 3 years UNLESS they see a direct vehicle modification to what broke. I know not all Dealers are the same.
    It is a personal decision and everyone should do what the feel comfortable with
    patos tacoma[QUOTED] likes this.
  10. Apr 4, 2025 at 9:25 PM
    #90
    patos tacoma
    I’m 66……..this truck could very well b my last new car/truck……..
    Thanx to the info on this forum, I bought one of the discounted Toyota Care warranties……..I added 4 more years to original factory warranty……..for @$650
    I hope Toyota built a terrific truck and I never have a warranty claim……..BUT,let’s look at just the economics…….@$650 divided by 48 months (xtra 4 year coverage).
    $13.54 per month ……….thats a quarter pounder, fries and a shake at McDonalds per month, or 2 Starbucks per month……for Toyota factory coverage…..AND if I sell the truck, I can transfer it or get money back…….
  11. Apr 4, 2025 at 9:44 PM
    #91
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Now do the scenario where the dealer claims your bigger tires caused increased strain on your transmission and it failed. Or a steering rack.
  12. Apr 5, 2025 at 8:00 AM
    #92
    K_Romer
    Ken
    I put bigger tires on, 33" the same size as the Trailhunter. I did 33" for that reason and because that is the largest that would fit as a full size spare. That isnt a concern for me.
    I see your perspective how it could be for others. We could go through lots of what if scenarios. I am not an expert and only can convey what I learned for my situation. To claim a position on situations I haven't researched would be wrong. I know lots of folks here like to make statements with a short review of the data. I am not one of them.
    You could be at risk with an Engine Tune, larger tires or weight bigger than the payload allows (Camper top) or you may not be at risk. I don't know. The first line of defense is the dealer, they don't exactly have a benefit to pushing back on a warranty claim. Doing a factory warranty claim is easy money for them. It depends on them if they are going to include data that would allow Toyota to deny the claim.
    When I had an 80 series Land Cruiser I installed a supercharger knowing full well that it would invalidate any warranty claims. I did that with my eyes wide open. I looked at the Tacoma engine tune data and decided it wasn't for me with the warranty.
    My main concern is the electronics and not the engine or tranny which I think are very relaible on their own.
    My situation is a bit different. I built the Tacoma for mild wheeling, but my primary wheeling vehicle is my 200 series Land Cruiser. The Tacoma is more my Daily driver even though I alterante between the two. If there is a challenging trail, the 200 goes. If I am towing my Australian Kimberley Karavan over a mountain, the 200 goes. If I am doing a light trail, I may take the Taco
    The warranty isnt for everyone and I am in no way recommending everyone should get it. I was surprized about the discount broker with a factory warranty and I did research to understand the impact of the modifications I wanted to do and how it would impact the warranty. I am confident that my 33" tires, CBI Sliders, rear ARB Bumper, future All Dogs springs and future ARB Front Bumper wont impact the warranty. The springs depend on my ability to align and even then, the warranty impacts would be limited to the CVs (In my Opinion).
    I am only trying to share what I learned and not beat the drum that the warranty is for everyone. I wouldn't get one if I was going to heavily modify my vehicle
    This last one is my supercharged 80 series Land Cruiser on the Rubicon with 35's
  13. Apr 5, 2025 at 8:59 AM
    #93
    OpeCity
    Long Beach, CA
    I’m not trying to discourage anyone from buying the warranty, and I’ll buy one for my truck in a few months. I’m just saying the magnussen-moss warranty protections aren’t as easy to use as one might hope. We all know that 33s shouldn’t cause a steering rack failure, but dealers push back on things like that.
    Look elsewhere in the forum, the dealer is jerking someone around about an evap canister failure. if it’s such a no-brainer to do warranty work and get paid, why would they refuse?
    patos tacoma and K_Romer[QUOTED] like this.
  14. Apr 7, 2025 at 7:42 AM
    #94
    Tacoma Dan
    Tacoma Dan Active Member
    Daniel
    Wichita
    2024 Tacoma TRD Sport Celestial Silver Metallic
    does troy have an email address? i tried the guy from midwest toyota and never heard anything back
  15. Apr 7, 2025 at 7:52 AM
    #95
    Yoda_Mike
    Michael
    You can send a request for quote via this web site.
    FD-Warranty
    Troy will respond in pretty short order.
    JB_TN and Tacoma Dan[QUOTED] like this.
  16. Apr 7, 2025 at 12:28 PM
    #96
    K_Romer
    Ken
    Troy Dietrich tdietrich@toyotaofgreenfield.com
    Factory Discount Warranty
    Toyota & Ford of Greenfield
    Phone. 413-775-6519
  17. Apr 7, 2025 at 5:16 PM
    #97
    K_Romer
    Ken
    I just got the warranty book from Toyota. Worthwhile getting to keep in the glove box. All the contact info you need and a member card for Roadside service. You have to call Toyota and request it based on Troy's note to me
    "It turns out that Toyota discontinued sending out what they’re calling “welcome packages” and neglected to inform their dealers (or their customer service reps). You can still request it though, you would just have to call TFS at 800-228-8559 and confirm your mailing address and they will send it out."
    WilliamJames and patos tacoma like this.
  18. Apr 10, 2025 at 4:20 AM
    #98
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
  19. Apr 10, 2025 at 4:22 AM
    #99
    Dbarffish
    Doug
    Montana
    Stock
    I also bought my extended warranty from Jerry. Very easy to deal with.
  20. Apr 10, 2025 at 9:09 AM
    #100
    patos tacoma
    I bought my Toyota Care thru Richard, 530-854-0458…..SF Bay Area…..
    Will beat or match any other price…..
