Extending new bilsteins to replace rear shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cland75, Aug 3, 2022.
  1. Aug 3, 2022 at 9:54 AM
    Cland75
    Cland75 [OP] Well-Known Member
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    So I purchased some new 4600s to replace my rear shocks and I cannot get either one of them to extend. I have put breaker bars thru the eyes and stood on the lower an tried to pull up with the upper an not even a slight hint of budging. Any tips for how to get these things extended so I can install them?
  2. Aug 3, 2022 at 9:58 AM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    Sounds like you purchased the wrong shocks
    Cland75[QUOTED][OP] likes this.
  3. Aug 3, 2022 at 9:59 AM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    Part numbers were checked on numerous sites and calls to local dealers.
  4. Aug 3, 2022 at 10:01 AM
    Brianz1001
    Brian
    too much to type
    There’s no trick to rear shocks, they either fit or they dont. Put them next to each other one old one new, are they the same length? Or close
    ToyoTaco25 likes this.
  5. Aug 3, 2022 at 10:06 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What is their length from eye to eye? And how much shaft is showing?
    Cland75[OP] likes this.
  6. Aug 3, 2022 at 10:15 AM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    The passenger side is 22in eye to eye with about 9 1/4 in of the shaft out measuring inside the cover
  7. Aug 3, 2022 at 10:16 AM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    I am def aware its not the right part but I cannot find another number for my 99 anywhere I have looked it up
  8. Aug 3, 2022 at 10:19 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    5 minute job, just put the bolts on and torque to spec.
    A quick search yields the correct shock part number and technical specifications IE lengths both extended and collapsed.
    https://www.suspensionlifts.com/sho...MIwfPCy5ar-QIVDQaICR0yYwLlEAQYASABEgJrbvD_BwE
    The shocks, without any weight on them, are already in their extended position. Extending them further will only damage them.
  9. Aug 3, 2022 at 10:21 AM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    Hmmmmmm very strange those are the ones I have but the shocks on my 99 the rear right is quite a bit longer then the rear left.
  10. Aug 3, 2022 at 10:23 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    "Quite a bit longer" is rather vague.
    And unless you're the original owner, it's hard to figure out what you removed without the parts themselves having an inscribed part number.
    I tend to ignore removed parts and simply install correct parts.
  11. Aug 3, 2022 at 10:26 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I can't tell from the OP if the shocks are stuck fully compressed or if you're trying to extend them further than they're designed to be extended.
    Giving you the benefit of the doubt.. is the truck jacked up funky with one side of the axle higher than the other or is there any type of spacer to make one side taller than the other? Any possibility you received 2 different shocks?
    Compare the new shocks vs the factory ones side by side and see what the length difference is.
  12. Aug 3, 2022 at 10:29 AM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    Yeah the ones on the truck are Toyota parts....have not removed them to see the part had Toyota put them on several years ago. The exact difference in length I will have to measure but bottom line is the link you provided an all the sites I have checked are listing those numbers but there is no way they are gonna fit on my truck. Was assuming the rear shocks would mount the same on all 99 SR5s and you can see by looking that the passenger side shock is certainly longer than the drivers side. Gonna have to pull them an get the numbers off of them an see what I can find to match I guess.
  13. Aug 3, 2022 at 10:33 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    His truck is a '99, and you're in the 1st Gen section.
    Assuming he removed factory shocks is a stretch. You'd have to assume he is the original owner and the rear shocks were never replaced which would make the shocks 18 years past due.
  14. Aug 3, 2022 at 10:34 AM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
  15. Aug 3, 2022 at 10:35 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Can you -
    Post a picture of the part numbers of your new shocks.
    Post a picture of your old shocks next to your new shocks.
    Post a picture of your truck's current position as you attempt to install the new shocks.
    whatstcp likes this.
  16. Aug 3, 2022 at 10:35 AM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    They are not original but they are Toyota made parts that were put on by the dealership in 2015
  17. Aug 3, 2022 at 10:36 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    TRD Tacoma's had yellow Bilsteins, but they weren't exactly 4600s that are offered today.
    The 4600s purchased (and linked above) actually have a slightly larger diameter body.
    Original shocks would've been physically skinnier.
  18. Aug 3, 2022 at 10:37 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Yes... He left out much information. But solid rear axle with leaf packs is pretty much the same setup though regardless of application when troubleshooting issues like this. My questions were vague and not directed at a certain gen. Just things for the OP to look out for and rule out.
    Why do you guys get so bent out of shape when someone with a 3g posts in another gen section? My questions were not 3g specific.
  19. Aug 3, 2022 at 10:38 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That was my first thought.
    Even a factory leaf pack can stretch longer than a factory shock allows.
    drizzoh likes this.
  20. Aug 3, 2022 at 10:39 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    2nd/3rd Genners post all the time! Super cool.
    Just can't make the same assumptions about certain things like factory shocks that's all. But you are correct about everything else.
