Extending wire.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Jan 31, 2017.
  1. Jan 31, 2017 at 7:44 AM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    How I go about extending the wire from the battery to the fuse box? Gotta extend it about 6 inches. What gauge wire is it anyone? ASAP thanks.
    ChadsPride likes this.
  2. Jan 31, 2017 at 7:49 AM
    Large
    Large Red
    I wouldn't extend it, just get a new piece of wire. If you're dead set on it though use a good butt splice lug, the size of the wire depends on the load you're going to run. I would do a minimum of #2 awg
  3. Jan 31, 2017 at 12:30 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I'd also be inclined to just do a new run rather than trying to extend the existing line.
  4. Jan 31, 2017 at 12:32 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    if you have to extend it 4 gauge is best. but you should just run new
    pinktaco808[OP] likes this.
  5. Jan 31, 2017 at 9:17 PM
    pinktaco808
    That be hard to get to. Anyone have a write up on changing the fuse box power wire to the battery terminal
  6. Jan 31, 2017 at 9:18 PM
    pinktaco808
    Y
    ou have a how too on running a new line?
  7. Jan 31, 2017 at 9:48 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    no I haven't done it. but it shouldn't be that hard to do. search for secondary fuse block in the the search it may help you out.
  8. Jan 31, 2017 at 9:49 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    what happen to your original one?
  9. Jan 31, 2017 at 10:10 PM
    pinktaco808
    It there
    It there, but the original one too short cause I have a bigger battery in there. It too short about 6 inches.
  10. Jan 31, 2017 at 10:19 PM
    pinktaco808
    Never really help
  11. Jan 31, 2017 at 11:50 PM
    pinktaco808
  12. Feb 1, 2017 at 5:51 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    I did this several years ago I just matched the original cable. bought from auto zone and bolted it to the existing one. you do have to take the post clamp off then put it on the end of new cable. should be easy I did it in a auto zone parking lot.
  13. Feb 1, 2017 at 5:52 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    don't forget to tape up the splice really good
  14. Feb 1, 2017 at 7:13 AM
    pinktaco808
    Where
    did you remove the existing stock wire from the fuse box or you just connected another same gauge or bigger wire to the stock wire?
  15. Feb 1, 2017 at 7:45 AM
    pinktaco808
    How
    How to on what he did exactly? Sorry kinda lost.
  16. Feb 1, 2017 at 7:57 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    https://youtu.be/LO9UgFbt1tY
  17. Feb 1, 2017 at 8:09 AM
    Pigpen
    Dan
    Northwest Montana
    Tape, really???
    Heat shrink it, don't use tape.
  18. Feb 1, 2017 at 8:19 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Even better heat shrink with adhesive (hot glue) helps hold the outer insulation together, and waterproof.
    Pigpen[QUOTED] likes this.
  19. Feb 1, 2017 at 9:34 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    hey when your in a jam you use what's available
  20. Feb 1, 2017 at 9:37 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    No I just put a 5/16 bolt in the two eyelets from the battery clamp. take the battery clamp off the exhisting cable, bolt the cable to the new cable at eyelets. put battery clamp on end of new cable
