Extented Stainless Steel Brake lines install question
Discussion in 'Suspension' started by sblea, Apr 25, 2016.
  1. Apr 25, 2016 at 12:33 PM
    sblea
    sblea [OP] Member
    Denver, CO
    Double Cab Longbed
    What have you guys done w/r to mounting extended SS brake lines on your aftermarket UCA and rear frame. I have some ICON UCA and snaped the screw for the OME bracket (still using rubber lines). I plan on upgrading to slightly longer ss brake lines (front+rear) and wanted some solid/clean mounting options.
