exterior audio idea
Discussion in 'Audio & Video' started by 95 taco, May 31, 2012.
  1. May 31, 2012 at 9:49 PM
    95 taco
    95 taco [OP] Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    ive been kicking around this idea of putting marine speakers on the roll bar im gonna build for my truck and i was wondering how i would go about setting it so i can flip a switch and the speakers come on with the other speakers inside the truck. any thoughts?
  2. May 31, 2012 at 10:00 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Is this music going to be for you or is it going to be so you can show other people how cool you are?
  3. May 31, 2012 at 10:05 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    For tailgating parties I assume.
  4. May 31, 2012 at 10:06 PM
    Nunavut
    Nunavut Eh oh, Canada go.
    Canada
    Cool idea :)
  5. May 31, 2012 at 10:10 PM
    JRez
    JRez Bruins are back!
    Jim
    Plymouth, MA
    01 Tacoma 2.7 4x4 SR5
    9000k HIDs, tinted windows (35%f 16%r), LED tails parking&blinkers, red LED dash swap, red LED under dash, red LED cup holder lights, smoked lights all around, H3 fogs under rear bumper, 2 JL w7 subs, kenwood 1000w amp
    If you wire them in with the regular speakers, get a double-pole switch and install it in the wire going out to them. Basically like doing any kind of lighting, just send the source & break it with a switch. you're just gonna want to break both the conductors on audio.
  6. May 31, 2012 at 10:11 PM
    Forster46
    Nick
    Mount Vernon, WA
    Would you have to install two separate switches for both conductors?
  7. May 31, 2012 at 10:16 PM
    95 taco
    for when me and my cousins are working/having fun.
  8. May 31, 2012 at 10:17 PM
    95 taco
    correct
  9. May 31, 2012 at 10:19 PM
    95 taco
    ok ill start doing research on a double pole switch. thanks for youre help. but one question that does a double pole switch do? i dont usually mess with audio or wiring.
  10. May 31, 2012 at 10:20 PM
    Brandon9402
    Brandon9402 uncoordinated dirtbox
    Brandon
    Mississippi
    02 prerunner sr5
    Kenwood headunit, 4 kicker 5x7 coaxials,2 memphis 1.5" tweeters, 2 12" memphis subwoofers, memphis 500w amp, chrome grille guard, kc fog lamps, chrome side steps, chrome tool box, and window visors
    I too have thought about this but I was thinking about the bottom of my toolbox (hidden until needed) since I don't have a roll bar
  11. May 31, 2012 at 10:23 PM
    JRez
    Jim
    Plymouth, MA
    I'm actually not 100% sure if they make double-poles for automotive application. i had one on an old truck of mine, but used an actually 120v switch. a double pole switch is just a normal switch only it breaks 2 wires with the single switch. usually has something on it like "1 in 1 out & 2 in 2 out"
  12. May 31, 2012 at 10:50 PM
    95 taco
  13. Jun 1, 2012 at 8:14 AM
    Brandon9402
    Brandon
    Mississippi
    02 prerunner sr5
    i think that should work. lol im not good with wiring stuff. but i believe it needs to have a total of 4 contact posts on the back (which im sure it does). 2 positive connectors and 2 negative.
  14. Jun 1, 2012 at 9:37 AM
    CrutchfieldDarren
    CrutchfieldDarren Well-Known Member Vendor
    Darren
    When it comes to loud outdoor sound an amp is a must in my opinion. You have to use good power to get the sound to travel outside.
    I would consider adding a small 2 channel amp for the roll bar speakers. Then you can just throw a basic spst toggle on the remote wire for the amp. Toggle on, sound outside and inside, toggle off, sound only inside.
  15. Jun 1, 2012 at 10:03 AM
    95 taco
    thank you for the help. ill look into that.
  16. Jun 1, 2012 at 10:25 AM
    ItalynStylion
    Steven
    DFW, Tx.
    That rocker switch might work. I can't see the back side of it so I have no idea. You will need two switches though; one for each speaker you're switching.
    And yes an amp would be nice but I'm assuming this is on a budget. Look for an efficient coaxial. Something like a wakeboard boat speaker that's meant to operate outside. Should solve the mounting problem too.
  17. Jun 1, 2012 at 10:46 AM
    95 taco
    ok thanks ill look into both options.
